Old 04-05-2005, 08:38 PM
FishyBC FishyBC is offline
Installing Trans Oil Temp Gauge
2 questions
1) What is involved in installing a Transmission Oil Tempurature gauge in a 98 Astro ?
2) Where do you run the wiring through to where it hooks into where it hooks into ?
3) Where is the best place to place the gauge once installed.
OK that's 3 question, I know !!!!
Thanks
FishyBC
Old 04-07-2005, 11:26 AM
astro fan astro fan is offline
Wink Re: Installing Trans Oil Temp Gauge
FishyBC,
It's funny you brought that up cause I was planning to do same on my 97. Here are my thoughts so far:
Buy an engine temp gauge kit at an auto parts
Remove the tranny oil pan (mine needs a filter and oil service anyways)
Have a welder weld a threaded fitting to the oil pan for sensor inst'n
Install new filter, gasket and oil pan
Fill tranny with new oil
Install gauge on dash (I have not determine position yet)
Do the wiring hook-up and
Bingo!
Hope this helps
Astro fan
Old 04-08-2005, 12:21 AM
As I understand it there are mechanical and electronic gauges. I'm guessing that you are talking about a mechanical one. I will probably whimp out and go with and electronic one. It just would be alot easier to install from what I understand..
I am working on getting an electric brake in this weekend. We'll see how far we get after that's installed.
I'll let you know when I know more. Do let me know how you make out.
