updated intake manifold gasket for 3400 V6 *edit
when did GM finally address the cheap head gasket issue with the 3400 V6? I seem to remember it being mid year 2003, but I don't know where heard it.
anyone know? if so, is there a VIN cutoff for the old one? Last edited by redly1; 04-05-2005 at 11:06 PM. |
Re: updated head gasket for 3400 V6
Do you mean the intake gaskets? I know GM issued updated intake gaskets along with intake bolts, and sealant to be used in the replacement procedure in July 2002.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Hmmm...good question.
Here's what I remember. THe 3400 has some top end gasket that caused a coolant leak into the internals of the engine (where water is NOT supposed to be). For some reason I thought it was the head gasket. I noticed on the GMinsidenews boards that someone mentioned in May 03, they finally switched from an intake manifold gasket made by Dana to one made by Reinz. There;s no real word on whether it solved the problem. Then someone else mentioned that in 04, the part number changed again...Hmm Anyway, how do you identify the date a Silhouette was manufactured based on VIN? (I'm guessing it involves some cross referencing) |
On my Intrigue there is a tag on the bottom of the left door with the date and the VIN. Not the SPID label with all the 3 digit codes, but a different label. You should have the same kind of label on the Silhouette. Look on all the door jambs, inside glovebox, rear hatch, spare tire cover, etc. It's there somewhere.
