Old 04-05-2005, 08:03 PM
89MiniMeReX 89MiniMeReX is offline
New Here
Well, this is my first import car so I'll start from the top. I needed a cheap car to drive since I had lost my job and couldnt afford my truck anymore. So luck came by me as my cousin who had a ZC turbo, decided to switch over to a B18C and had bought and 89 CRX with the complete swap. After we took the motor out I asked him if he would sell the car to me for $100. He said fine. Now all I needed was a motor so I asked his brother who is doing a ZC turbo swap to his 91 CRX if I could buy his Si motor for $80. Well now I have an 89 CRX with an Si motor. I am still buying parts for the car but so far I have bought a Z6 Vtec head for the Mini-Me swap ($200) an Apexi Vtec controller ($250) adjustable cam gear ($65) and an Si tranny with a stage 2 clutch ($150). I still need the wiring harnesses and exhaust but I have no clue what to get for the exhaust, any suggestions? Also I have heard with doing the Mini-Me swap I will have a high compression, making it very tough to run forced induction, anyone know of pistions I can use to lower it? I can't think of much more but would aprreciate some help. Thanks
Old 04-06-2005, 08:08 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
hey, welcome. sounds like a cool project
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 04-06-2005, 08:21 AM
travagliante's Avatar
travagliante travagliante is offline
Re: New Here
Since your car is MPFI, the wiring wont be really hard.. I would sugguest selling the vtec controller and buying a obd1 ecu-p28 5spd one, and getting a obd0-->obd1 conversion harness and converting to obd1. Also the head will raise compression higer. When you buy the headgasket get a thicker one than oem, that should help a little.
Old 04-06-2005, 10:11 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Re: New Here
welcome
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 04-06-2005, 01:27 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Re: Re: New Here
I would also suggest this. Car will run much better this way.
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-06-2005, 04:27 PM
Cool, thanks for the help. I heard of getting a thicker head gasket but I heard getting different pistons would lower it also, although I am not sure which ones I would get. About converting to obd-1 I do plan on doing that but I need some cash to get it done first.
Thanks again
