Old 04-05-2005, 07:49 PM
Canabalooza Canabalooza is offline
leaking radiator fluid
So I was going over a bump and hit a piece of metal and thought omg I just broke my car. Everything was ok but I noticed this little valve spout thingy that was leaking radiator fluid. here’s a pic,
Any ideas why? Or is it supposed to do that. I have an 89 crx.
Old 04-05-2005, 08:43 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
Re: leaking radiator fluid
check if it has a hose that goes to it, is that the twist off thingee that drains or some kind off spill off?
Old 04-05-2005, 09:48 PM
i looked all over to find a hose and i cant find anything it dosent leak a ton it drips some. the twist thingy isnt leaking its the little spout and i think the twist thingy drains the radiator.
Old 04-05-2005, 09:52 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
the "twist thingy" as you guys put it is actually called a radiator drain cock. when u un screw it, coolant will come out of that spout. when its undone all the way it comes out both holes. if your car leaks out of there yours might be cracked. toss a pan underneath to catch all the coolant and pull the drain cock out. if its fine then i dunno, try to tighten it all you can and see if it stops
Old 04-05-2005, 10:34 PM
Scott82 Scott82 is offline
take it out and put blue rtv on it and screw it back in and let the car sit for about an hour and it shouldn't leak.
Old 04-05-2005, 10:49 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yup thats the drain spout the twisty thing controls it. try see if its loose or cracked
Team Lonely Drivers
Old 04-05-2005, 11:41 PM
Lightbulb Re: leaking radiator fluid
THANX 1PHAT CX I THOGHT WEED BE CALLING IT THAT ALL NIGHT. I KNEW SOME ONE KNEW WHATS IT WAS CALLED, ALTHOUGH HIS PROBLEM LOOKS LIKE SOMETHING ELSE...
