Warm start
Alright ever since I got my car, if you were driving fully warmed up, parked and came back after a little bit if the engine was still warm it wont run right at idle untill you drive a few seconds. Today I came home parked and went inside. I came back out to leave about 20 minutes later and the car wouldn't stay running for more than a few seconds and just cut off. If i started it and gave it gas it would sound like it was knocking?? which scared me so I stopped. A little over an hour later after sitting in the garage with the hood open to cool it started right up and ran fine. What's causing this and why is it getting so bad?? advice? sorry for the long post.
Re: Warm start
maybe IAC needs cleaned.
Re: Warm start
Could be the vac line that goes to the FPR, or the FPR solinoid
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
Alright, I'm going to clean the IAC and ask this question on 3si also. Noone else has this problem? If I get it figured out ill post what it was...Thanks
Re: Warm start
vac lines are fine.... cleaned IAC did nothing =;\
Re: Warm start
do you have a vr4? it means your turbos are flooded. either 1) buy a turbo timer or 2) let the car sit/idle for 1 minute before you shut it off.
fixed. happened to me all the time before I knew what was going on.
'92 3000GT VR4 Current Mods: K&N FIPK RPS Streetmax clutch Rebuilt tranny Free Boost Mod Maximal Performance Solid Motor Mounts Pictures and Videos of my car Got a question about your auto insurance? I'm an insurance agent, ask away. |
Re: Warm start
Turbos are flooded? Could you explain a little more?
Re: Re: Warm start
Re: Warm start
if you run your car, then shut it off fast, your turbos get flooded, and if you try to start your car like 10 minutes after you shut it off it will run very rough, like it wants to die, and you have to pump the gas for about a minute to unflood them (while the car is running) or let it sit for 1-2 hours.
omaro, you need to increase the time before your TT shuts the car off. You need to let the car idle longer.
Re: Re: Warm start
Re: Warm start
try 1:30 or 2:00.
Re: Warm start
I guess i was more looking for an answer to what turbos flooding is. There is no fuel going to them, and generally when someone says the engine is flodded it means there is to much liquid fuel sitting in the cylinders for the engine to fire.
Re: Warm start
i think when Gateway says "turbos flooding" he is referring to the oil that can get clogged in the turbos if the car is turned off immediately, without giving the car enough time to circulate the hot oil through the lines and the oil cooler to cool off.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: Warm start
But that doesnt stop the car from starting, it just makes your turbos fry sooner, which it the reason our turbos have water lines, and using synthetic oil furthure cures this problem.
Re: Warm start
well that was the only thing i could glean from "turbos flooding". do you have any thoughts talskin?
