Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-05-2005, 07:15 PM
blackcivic19 blackcivic19 is offline
apex vafc
Ok the problem is this, I installed the vafc from apex and now my cel is on.
I did a diag. and codes 07 throttle position sensor and 21 vtec solenoid are coming up.. I rechecked all my wires and everything matches up to the info I got from apex site.. Has anyone had this problem or no a solution .. Also any info on tuning my jdm b16 to a vafc that will help me out too...thankx alot
Old 04-06-2005, 01:40 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: apex vafc
I am willing to bet your wiring is not correct somewhere. It would help to know what car this is in.
Old 04-06-2005, 01:44 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: apex vafc
dotn post the same thing in 2 different forums. just one
Team Lonely Drivers
Old 04-06-2005, 02:18 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
Re: apex vafc
did you follow the directions exactly when you installed it? my guess is you wired it bad, maybe cut the tps wire?
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 04-06-2005, 05:50 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: apex vafc
disconect it sell it to some ricer kid fix your problems
Old 04-07-2005, 09:58 PM
Re: apex vafc
Ok figured it out. I went over all my pinouts and everything matched. My vtm signal wire wasn't wired right. all I had to do was cut the end coming from the car because that gets dead ended, and leave the blue vafc wire hooked up goin to the vtm signal to my ecu..
sounds confusing but if you installed one you will know...
