Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 04-05-2005, 05:57 PM
batman19 batman19 is offline
Send a message via AIM to batman19
popping noise when turn
when i turn ( doesnt matter left or right), it will hear a popping noise, quicker i turn, more popping it gets.
i told my truck to the shop and they cant not make that noise again and tell me i should change my lower ball joint.
Does anyone have that happen b4, and what was wrong?
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 04-10-2005, 01:56 AM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Re: popping noise when turn
It may be a ball joint. Before I even knew what balljoints were I noticed popping when turning and took it to my gampas dealership. It was a balljoint and they said I was lucky a wheel hadn't flown off. I would have it looked at asap!
Old 04-11-2005, 09:40 PM
was it upper or lower bjoint? which one did u change?
1997 Civic HX
1.6 D16Y5 engine
Auto with 55K
STOCK
Old 04-11-2005, 10:08 PM
chcknugget's Avatar
I didn't change it, the shop did. I saw the part when it was done and it looked like an upper ball joint, but don't quote me on that. It was pretty beat up to say the least.
If the shop told you a ball joint was bad I would just have it done. Bad balljoints aren't good to drive around on.
Old 10-11-2005, 09:13 AM
xxkcjhxx xxkcjhxx is offline
You should check the pitmen arm or the idler arm, i just had mine replaced. It all depends on what direction your turning when it happens. There about $50, if you do it yourself it's not that bad.
