Old 04-05-2005, 04:35 PM
andrewshih andrewshih is offline
Question A/C problem?!?
Hi all,
I have a 1991 Honda Civic Sedan with the factory A/C system. The A/C would run when I turn it on, but if I sit at a stop light and a car idles for too long, the compressor (or whatever component) would stop and the A/C would not come back on. This also happens when I drive too slow or fast (I think it's something to do with the engine compartment not getting enough air flow, slow driving; or engine working too hard, fast driving)
What component should I be checking to see if it needs replacing? Summer is coming and I live in GA....... I need help, fast!
Old 04-05-2005, 04:39 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: A/C problem?!?
lol i hear ya, florida is gettin hot! does the ac turn back on if u shut car off n turn it back on again?
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 04-05-2005, 04:40 PM
Scott82 Scott82 is offline
Re: A/C problem?!?
try to add some freon to the sys. If it gets low it will not come on, in your case you may just barely be low which when your higher rpms it generates enough pressure in the line to let it kick on.
Old 04-05-2005, 04:54 PM
Is that something I can do on my own? Or do I have to be a certified mechanic to purchase freon and related parts?
Old 04-05-2005, 08:57 PM
icE_x's Avatar
Re: A/C problem?!?
get a kit from like autozone or walmart, you can buy the cans at walmart for a few bucks each - i did it the other day because my freon keeps leaking out, very easy to do
Old 04-05-2005, 10:00 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
Re: Re: A/C problem?!?
freon is very poisonous. i'd get that leak checked out asap and get it fixed, you shouldnt have passed a safety like that. also i know up here u cant buy freon. u need to have a certified technician re-charge your system.
Old 04-05-2005, 10:40 PM
Re: A/C problem?!?
i fit is 134-a you can buy it at walmart and do it your self they have a kit. If it is a R-12 sys then you have to have a license to purchse it but it goes in the smae way as the kit from walmart. If you know anyone that works on house hold ac and stuff they should have the same a/c gas that you have weather it be R-12 or 134-a but r-12 is much more expensive. If you have a leak i suggest to convert to 134-a so that if you have a leak in the future it dosn't cost an arm and a leg to refill the freon.
