Oil Pressure -- oil breakdown by heat?
I have a 96 Z28. It runs well, and doesn't use oil. The problem is that between changes as the oil gets more miles the pressure drops off at idle.
I changed the oil about a month ago and the pressure had been holding. However, just this weekend, I was stuck in city traffice, and the engine ran hot -- not too hot just up near the red. While it was hot I noticed that the oil pressure was always going into the red unless I kept 1500 RPMs. I thought that after cooling down the problem would go away. It didn't. Yesterday and today, when the engine is warm but no ways near that hot, the pressure still falls off. Did the oil break down because of the heat? I am thinking that a synthetic might hold up better to the higher temps of an LT1 engine, but mine has 97K miles using a good grade Castrol oil. Would it be bad to switch to a synthetic? Thanks for any thoughts. |
Re: Oil Pressure -- oil breakdown by heat?
Has the car been driving normally ?. If so sounds like a faulty oil pressure send unit. What is the pressure that you consider low?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Oil break down is mostly from being flung and chopped and splashed and used. Unless you are running a turbocharger
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
I believe he was referring to Viscosity breakdown...doubtful that is happening. what is more likely is that the oil is thinning out as it gets hotter, also may be getting diluted by crankcase contaminants, gas, water (condensation) etc.
What is the actual number registered on the oil pressure gauge? At normal road speed a 350 should be 35-40 PSI.
1973 Z-28 1965 Nova 1950 Packard 1996 El Dorado Touring Coupe There is no substitute for cubic inches |
