Go Back   Automotive Forums Car Chat > Nissan > Cedric | M45 | J30 | Gloria
Old 04-05-2005, 01:09 PM
i3a0g i3a0g is offline
Send a message via AIM to i3a0g
speaker sizes
i know the stock front speakers are 4", does anyone know how to put a 6.5" speaker in there? could i simply take out the speaker and the bose amp? or does other work need to be done
has anyone done this yet?
Old 04-05-2005, 10:50 PM
idcp idcp is offline
Send a message via AIM to idcp
im sure its possible but you would have to cut the bose plastic box. i have a 5 1/4" in it and i didnt have to cut out much. or you could make a speaker pod that mounts to the door. the door has 4 screws which mounts a abs plastic box with a vent the box is air tight and screwed together with about 20 machine screws. also the bose amp is inside the box. to run anyother speaker without using the bose system you will need to take the box apart. i would try to cutout the extra plastic so it will fit a 6 1/2 just make sure the speaker will fire threw the grill on the door panel. also that the grill on the door panel doesnt prevent the speaker from moving when put back on the door.
