Old 04-05-2005, 09:06 AM
dmplefty dmplefty is offline
Angry 94 Cherokee Headlight
the head lights on my Cherokee wont turn off, I have checked the fusses cleaned the leads on the headlamp and finally removed the switch and they remain on, any ideas on where to go from here would be great.
Old 04-05-2005, 10:13 PM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: 94 Cherokee Headlight
Does your high beam switch still work? It should be able to activate the high beams and the dash indicator (flash feature) even with the headlamp switch off. It could be stuck closed causing your problem. Good luck and let us know what you find.
Mark's Garage est. 1983
Old 04-06-2005, 09:24 AM
The high beams and flashers work fine, I did find a short up under the hood near the driver side head light, does any one know if you have to replace the whole harness if so where can I get one of them with out paying an arm and a leg!
Old 04-06-2005, 11:06 PM
Re: Re: 94 Cherokee Headlight
You should be able to make a repair on the exsisting harness. If done clean and tight it will work fine.
