Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 04-05-2005, 12:53 AM
g--thang g--thang is offline
Question TIRE SIZES who knows this??
what is better on a 2000 honda civic 4 door
i am getting DAI RACER mags 16" (15lbs)
and i want to know which size tire is better
195/50/16
or
205/45/16 (will the 205s rub the walls when i turn???)
which size is better
take into consideration that there are many pothole here in Montreal
and the tires and mags will catch a beating
LOL
Old 04-05-2005, 01:26 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: TIRE SIZES who knows this??
205/40/16 will give you the widest tire without rubbing and the right sidewall height to keep your speedo as accurate as possible.
Empty Pockets Racing Member #1
Old 04-05-2005, 07:36 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Re: TIRE SIZES who knows this??
Actually for a 1992-2002 Civic 195/55x15" or 205/45x16" would keep the odometer and speedo more accurate.
I'd get the 16" wheel combination and make sure you get 16x7" with 42-44mm offset to prevent rubbing.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-05-2005, 01:27 PM
GScivic7's Avatar
oh...I used one of those tire size calculator things too...
Old 04-05-2005, 02:17 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Well it depends on what size the original tires are. Like with the '92-'95 CX and VX; the correct tire size would be 195/50/15. It's because they came with 175/70/13 tires on there. The 175/70/13 would have a radius of 287.1mm. The 195/50/15 would have a radius of 288mm. And the 195/55/15 would have a radius of 297.75mm. So the 195/50/15 would be a lot closer to the 175/70/13, than the 55's. Of course that's not anything to do with the rubbing question, but for speedo and odometer accuracy.
