Old 04-05-2005, 12:23 AM
patfogle patfogle is offline
Send a message via MSN to patfogle Send a message via Yahoo to patfogle
VSS location
Hey all, I'm installing an aftermarket cruise control system and need to know the wire colors and locations for the tach signal and VSS signal. Thanks in advance...
Old 04-05-2005, 02:07 PM
SebringYves SebringYves is offline
Re: VSS location
Regarding the vehicle speed sensors:
wiring colors:
left front: tan/orange (521) + tan/black (522)
right front: yellow/red (514) + yellow/black (516)
left rear: light green/red (518) + light green/black (519)
right rear: pink/red (523) + pink/black (524)
The speed ref signal is on cable: 521, 514, 519, 524
the speed sensor is sensor and a ring with teeth. Everytime a teeth is passing the sensor a electrical impulse is generated which is sended to the ABS control module. The electric impulse is in direct proportion to the rotation speed of the wheel.
Old 04-24-2005, 09:41 PM
Re: VSS location
Okay, if there are 4 sensors where does the speedo get it's signal from? That is the wire I need, and the tach signal. The cruise kit needs both (and a vacuum source) to work properly.
Old 09-23-2005, 10:57 AM
miller124 miller124 is offline
Re: VSS location
I am replacing a speed sensor in a 97 winstar and I am having trouble locating it. Help
