Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 04-04-2005, 11:22 PM
numskull26 numskull26 is offline
89 trooper, no power to fuel pump
trooper died on me mid stride while driving down the road like it just flicked a switch off, I't seems there is no power to fuel pump , I've checked all fuses , the relay in fuse box replaced, where else is there a relay or fuse or fusable link damb chiltons are stupid, I think they are in kahootz with auto repair shops or whatever that conspiracy is , I swear I'm ready to go buy an old 77 chev or something without any computers.Well thats a whole nother topic..... well any help is appreciated.
Old 04-05-2005, 10:06 PM
help, help , help
someone that knows please post, where are the fusable links at? or what else should i look for?
Old 04-09-2005, 08:14 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 89 trooper, no power to fuel pump
1. Pull the fuel pump and see if it still works (wire it directly to a 12V battery and see if it hums).
If so the pump is most likly good.
After that you will have to see if you have a break in your wireharness. And/or run new wires.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-09-2005, 11:21 AM
Re: help, help , help
I was wondering if i could just run new wires or if it would mess up the computer? I was going to attempt to just wire it into the ignition so it's on when the key is on, would that work alright?
Thanks for the reply
Old 04-09-2005, 11:28 PM
Isuzu Guy
...but you don't know if the pump is good? forget the wires until you know the status of the pump.
-Ryan
Isuzu Moderator
Car Show Tips
Old 04-10-2005, 07:15 PM
Re: Re: 89 trooper, no power to fuel pump
well i disconnected the plug at the tank and tested it and there's no juice so I am asumeing the pump is fine.
Old 07-28-2005, 09:50 PM
89trooper 89trooper is offline
my brother had the same problem on an 88. if you bypass the relay and still don't get 12v to the pump the wiring to the fuel tank is bad. his was broken inside(the insulation was still good but the wire inside was busted) about 4 inches from the plug on the harness side(not the pump side)
email me at [email protected]
