Old 04-04-2005, 10:28 PM
mrpibsk8er mrpibsk8er is offline
Send a message via AIM to mrpibsk8er
Lightbulb side mirror turn signal wiring
hey everyone, I actually just got started in imports, but I have the mercedes style mirrors for my 92 civic hatch and I got them bolted on right. there are three wires coming out of the mirrors, a blue a white and black. I'm pretty sure the black is ground but I don't know what to hook the others up to. any wiring diagrams or advice would be a lot of help. thnx
Old 04-05-2005, 04:19 PM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: side mirror turn signal wiring
Got this from this site check it out see if it applies.
http://www.x3racing.com/install_guide_m3mirror.asp
Once the mirrors are installed on door assembly wire up the mirrors according to what color and function you want on the mirrors. The blue wire is for the blue LED’s, the white wire is for the amber LED’s, and the black is ground. If you want the blue as a signal light, then wire it to you signal lights, if you want it to be on in unison with the parking lights, then wire it to your parking lights. The same will be true for the amber. YOU DO NOT HAVE TO WIRE BOTH COLORS.
03.IS300.MT.LSD. 'Supra in Training'
Old 04-05-2005, 04:51 PM
thanx a lot do you know where to wire them to? the fuse panel... maybe?
Old 04-05-2005, 07:46 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
I would suggest: Mount them first off all, run the wires down your fender, and connect them to your actuall turn signals! It's easier than it sounds, You may have to remove the fender though , but it's not hard!
Good Luck,
Please Post Pics.
Ya, It's Turboed.
Old 04-05-2005, 10:51 PM
aight thnx, but I already do have them mounted as it says in the first post^
Old 04-05-2005, 11:10 PM
http://files.automotiveforums.com/ga...hp?photo=40780
