Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 04-04-2005, 06:37 PM
burkey41 burkey41 is offline
Shift Solenoid?????
Hey guys thanks in advance for any help or info. I have a 95 4.3L vin W
and my SES light came on the other day and my vehicle wasn't shifting quite like it should so i went to the local autoparts store and used the code reader. I got a P0756 code and also said shift solenoid B performance or stuck off. does a ground or anything every go bad on that solenoid and how involved of a process is it to change. Thanks for any info and input.
Old 04-05-2005, 05:38 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Usually the solenoid just goes bad. To acess the solenoid you need to drop the transmission pan. (Good time for a fluid and filter change) If you are lying on the ground on your back with your feet sticking out the front of the truck, you will see 2 solenoids towards the rear of the valve body. B is the one on the right. Replace both of them anyway.
Old 04-06-2005, 06:43 PM
Thanks for the help rlith. I had to have the solenoid shipped from a warehouse the local parts store didn't stock it, but it shouldn't be a problem once i get thanks again for the help
Old 04-08-2005, 06:09 AM
rlith's Avatar
Re: Shift Solenoid?????
Let us know how it turns out!
Old 04-09-2005, 03:00 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You just pop them out and pop in new ones?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-18-2005, 08:39 PM
wankel7 wankel7 is offline
Send a message via AIM to wankel7
Update!
Had the same code and many other problems.
How did it not shift right?
