Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-04-2005, 06:11 PM
9000vtec 9000vtec is offline
quick question
what year of eclipse gsx gst have less of crankwalk happening except 1gen
Old 04-04-2005, 06:18 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
98 and 99 as far as i know.
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 04-04-2005, 06:20 PM
Re: quick question
now if u get gsx will crankwalk happen to u for sure after while or do u have to push it hard to happen
the quastion is does it have to happen?
where will crankwalk happen more ofte talon 97 tsi awd or gsx 98
Old 04-04-2005, 06:27 PM
1g90gsx's Avatar
read this,
http://www.magnusmotorsports.com/crankwalktheory.htm
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AUTOMETER
ROTA CIRCUT 8"S
Old 04-04-2005, 08:18 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: quick question
crankwalk isn't very common. it mostly happens after someone rebuilds the engien and my personal opinion is that the person assembling it screwed it up.
btw your vtec honda can crankwalk too. any car can do it the real term is "thrust bearing failure"
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-04-2005, 08:47 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Re: Re: quick question
agreed...any motor can crankwalk in any car...it happens more commonly in the 2nd gen eclipses because when mitsu switched to the 7bolt 4g63 they picked up some shitty cranks (at least that's what i heared)...there's different theorys out there though about why our cars can get it. like poor oil circulation, beefier clutches with more holding force, starting the car with the clutch in, etc etc.
Old 04-04-2005, 09:17 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: quick question
i have also heard its less likely on a 98 or 99
Something new is coming...
Old 04-05-2005, 12:50 AM
coolguycooz coolguycooz is offline
the best thing you can probably do is never let your oil level drop dont hold the clutch in and start saving up money for the 6 bolt swap when it does happen anyways.
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it")
98 GSX 5 spd. (Currently stock, spending all my mod money on body work.)
Old 04-05-2005, 12:59 AM
Back's Avatar
Back Back is offline
Banned
Re: quick question
How do you starts a car w/o pushing in the clutch?
Old 04-05-2005, 01:07 AM
TreeFrog's Avatar
Re: quick question
un hook the clutch switch
Old 04-05-2005, 01:47 AM
ned032002's Avatar
ned032002 ned032002 is offline
OK have a couple of questions, first how do you un hook the clutch switch? Also what is crankwalk in a nut shell and how does putting in the clutch when you start your car effect anything?
Old 04-05-2005, 01:50 AM
the clutch switch/wire should be a little green wire under where your clutch pedal under the dashboard area. Crankwalk is thrustbearing failiur its when your crank starts moving when its not suppose to do that it starts to rub off your crank position sensor until your car wont turn on. pressing the clutch when starting the car puts stress on the crank when there has been no oil circulating through it. im not an expert or anything but you can research it there are a bunch of websites out there explaining it and why they think it happens and possible "Fixes" <== whatever
and stuff like that. just look it up. any car can get it just the 7 bolts get it alot more then normal.
Old 04-05-2005, 01:54 AM
ned032002's Avatar
Sorry I felt retarted when everybody is talking about crankwalk and All I'm doing is shrugging my shoulders. By unhooking the wire that won't hurt the car at all also will it through a CEL?
Old 04-05-2005, 02:01 AM
nope. plus if you want to get that auto start crap for your manual you have to do it anyways. i always thought it would be pretty nice to be walking to your car press your button and start idleing your car while your smoking a cig then when you finally get up to the car its all warmed up ready to roll.
Old 04-05-2005, 01:36 PM
Re: quick question
atualy own eclise gst lol but im lookign for new car
i have few options i used this name becaouse every name i type is taken
96 civic hatchback with gsr engine 8500$ and some type r parts +rims
98 contour svt 60k 5800$ new engine with warenty
97 ford probe gts 6800$
98 civic vtec with alot of boltons except turbo +body kit + rims
and maybe gsx what why i asked these questions have obout 4 of them in 7-8$ range
and talons tsi awd 2 gen
now i hear some of u say its week bolts in eclipse that starts crankwalk
i saw on ebay called crankwalk fix somethign like it comes in few parts was few months back so i forgot what is called so if u get gsx should i looks for stronger bolts and raplace it as soon as possible ?
Closed Thread
