Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-04-2005, 04:41 PM
SSlethal SSlethal is offline
95 bonneville oil cap vacuum
have a problem with a 95 bonneville , when i take the oil cap off the engine almost dies and there is a suction at the cap and also at the dipstick. like if i put a hose on the dipstick it sucks better then a hoover lol. is this normal
Old 04-04-2005, 05:42 PM
LMP's Avatar
LMP LMP is offline
Re: 95 bonneville oil cap vacuum
When the oil cap is on, it prevents the intake manifold from taking a large intake bypass through the positive crankcase ventilation (PCV) valve but when you remove the oil cap, the engine takes a large amount of intake air through PCV valve and that bypasses the normal air and fuel mixture feed. I'm not sure if that is 100% normal..I would suspect your PCV valve is stuck opened.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-04-2005, 05:49 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
The PCV is located inside the upper plenum. Sometimes when the PCV is replaced a small black o ring that goes around the PCV is not replaced onto the new PCV which would cause your problem.
I would remove the PCV and check to see if you have this o ring on the PCV.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 04-05-2005, 08:40 AM
there is a cap on the front of the engine on the plenum that says pcv. it just twists off, but when i open it there is nothing there that looks like a pcv valve normally would.there is a o-ring on the cap and it is in place.but like i said the hole is empty.and i forgot to add that it is the 3.8 incase that matters.
