I have a 97 dodge ram 2wd i have had the trans rebuilt once and this problem occured before and after the rebuild. driving the interstate about 70 the rpm kicks up and then back down like the od is kicking in and out. i can speed up or slow down and the problem stops. i also tried octane booster and it seemed to stop it . any ideas?
Re: od drive kicking in and out
are you sure that it's actuailly kicking out of OD?
how much do the RPM's jump? I had a similar problem with my 99. wile cruising at a steady speed(cruise controle on or off didn't matter) the RPM would jump about 200 or so, then come back down. what my problem ended up being was the torque converter unlocking, then locking back(not actuaily coming out of OD). turned out to be a bad TPS (Throttle Position Sensor). it had a bad spot in it, and was sending a bad signal to the computer, which was causing the converter to unlock. you can test the TPS with a volt meter, and if it is bad, it only costs around $25, and you should be able to get it at most parts stores. if you need directions on how to test you TPS, let me know and I'll post them here.
when all else fails, get a bigger hammer. ![]() Vehicles: 2005 suburban 1500 4x4 all stock, ex-fire department truck. 1987 Grand Wagoneer |
thanks I will test it just need to look in mitchelle's to see the ohms reading correct.
