Old 04-04-2005, 12:36 PM
BlulytesTB's Avatar
BlulytesTB BlulytesTB is offline
Shocking - Static Charge?
Does your TB shock you when you get out?
I noticed almost every time I get out of the truck I get a nice zap when I go to close the door. It happens in one of my friends TB, but not another's. Does it happen in yours?
Noticed w/ Cloth Seats.
2004 Trailblazer LT
Old 04-04-2005, 06:03 PM
DamonZ28's Avatar
DamonZ28 DamonZ28 is offline
Yes, I get a huge shock. I just figured it was the time of year, and the fact that it's a new car.
2005 Trailerblazer EXT LT 4x4
Medium Red Metallic
Old 04-05-2005, 07:04 AM
fhall1 fhall1 is offline
Re: Shocking - Static Charge?
Mine does too (it's an '03 - so it's not new)...especially when I'm wearing sneakers. If I remember, I read of a trick where you touch your key to a metal part of the door before you touch the door with your hand and it dissipates the static without shocking you...but I don't remember to do that all the time.
Old 04-05-2005, 07:22 AM
98RKC 98RKC is offline
Hold on to the door ( I use the window frame) while you are still sitting on the seat and continue to hold until you get out. When your feet touch the ground it takes the shock away. My 04 would shock me more than any other vehicle I've ever owned.
Old 04-05-2005, 01:10 PM
The Black Pearl's Avatar
The Black Pearl The Black Pearl is offline
I noticed this myself. I mentioned it to my wife and she had told me about the dangers for women pumping gas then going back into the car to get their purse, the shock may ignite the gas. She had scene this on a TV report. She had mentioned that it is the friction from the cloth interior.
Check out my GM experience
http://www.automotiveforums.com/vbul...d.php?t=389060
2005 Red Santa's Sleigh c/w Toyz (MINE)
2004 Black Chevrolet Extended Trailblazer (ALL MINE)
2002 Silver Mazda Protegé GT (Hers)
Old 04-06-2005, 07:59 AM
BlulytesTB's Avatar
OK... here is the FD response to that. Is it possible to ignite the gas fumes while pumping? In 99.9% of all occassions it is not due to static electricity. Been a FF for 10 years and we have never had a pump fire due to static electricity. "Mythbusters" a show on TLC (I believe), did experiments around cell phones, static electricity and fuel pumps. They were unable to generate a fire from either exposure. The reason? Most pumps now have vapor recovery, which limits the amount of fumes which go back out into the air (the rubber nozzle over the pump). Even without this device, the concentration of fuel in the air or LEL (lower explosive limits) which is required for an ignition point of gasoline is still relatively small. For example, if you were in a confined, non-ventilated, space, your chances for an explosion would be higher. I have not found a pump like this yet... would be nice in the winter! However, we are outside, where the usually is a breeze or some type of air movement.
The safe rule... if you are going to get back into your vehicle while pumping gas, when you get out, just touch the side of the gas pump on any metal surface. These devices are fully grounded and will "de-energize" you.
Stay safe!
-Joe
2004 Trailblazer LT
Old 04-06-2005, 06:58 PM
Here is one of the articles I have read on the subject about static electricity and pumping gas. I didn't have to search to hard for this article, but I do not know if this is the one my wife was talking about.
http://www.cbsnews.com/stories/2004/...in638947.shtml
Old 04-06-2005, 07:25 PM
BlulytesTB's Avatar
Pretty good video, I might be crazy, but doesn't the video of the fire actually look like a trailblazer?
Be careful with those types of nozzles, they don't have the "vapor recovery" which I was referring to.
Vapor Recovery Nozzle
Be Safe!
2004 Trailblazer LT
Old 04-06-2005, 09:00 PM
Thanks for pointing out that there was a video, I just watched it. I will now tell my wife to touch the door before touching the pump. Getting back to the original post, I get zapped by my TB every time and now I have to touch the door frame knowing I will get zapped before I fill up.
In Canada I only see the nozzles with the splash guards. Never come across that type of nozzle.
Old 04-08-2005, 11:11 PM
trailsharky trailsharky is offline
mine does, although it mainly depends on which pair of shoes I have on
Old 04-16-2005, 11:42 PM
demo21r demo21r is offline
Static Shock
Tired of getting a charge out of your ride.
Try using static gard used for clothing worked on mine.
Old 04-18-2005, 07:37 AM
BlulytesTB's Avatar
Re: Static Shock
well said! Will try
2004 Trailblazer LT
