Old 04-04-2005, 11:49 AM
ned032002's Avatar
ned032002 ned032002 is offline
How do you fix high idle?
I found that the problem I was having with my car before was not exactly fixing itself so I just changed the throttle body. Now the problem is gone but now I have pretty high idle ONLY when the engine is cold. The idle is up near 2000 RPMS, they drop down near 1000 RPMs when the temp is at normal running. No CEL is thrown but the hight idle is really annoying. I did adjust the idle from the screw hidden by the rubber plug, does anybody know if the green wire that sits right next to the throttle linkage on the trottle body has anything to do with the idle? I believe it does because the wire is connected to a screw like thing that has a springy end on it so when the idle is engaged the throttle sits right on the spring. Would adjusting this help?
Old 04-04-2005, 12:13 PM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: How do you fix high idle?
Make sure your cable is not to tight. That will do it to. I don't know about the green wire.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-04-2005, 01:56 PM
ned032002's Avatar
Re: Re: How do you fix high idle?
I know that the wire isn't too tight because the idle calms down alot when the engine is at running temp, so I don't think it could be the cable.
Old 04-04-2005, 06:18 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
You could try to adjust your BISS..Base Idle Set Screw... or the TPS could be off by just a bit...
I believe the idle when warm should be about 8-850 and when cold around 12-1400... in that ballpark anyways... Mine was higher like that and boostedspyder told me I could adjust the BISS and it helped... I had another problem but don't know what it was....the biss helped though....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 04-05-2005, 01:28 AM
ned032002's Avatar
Originally Posted by 96spyderman
You could try to adjust your BISS..Base Idle Set Screw... or the TPS could be off by just a bit...I believe the idle when warm should be about 8-850 and when cold around 12-1400... in that ballpark anyways
When I first start the car the idle goes up to about 2000 and when the temp is about normal the idle drops to about 1100. Also I noticed that I have a idle surge only when the car is cold now? The BISS screw that your referring to is that the "sensor" that has the green wire coming out of it because I tried to turn down the idle by loosening that screw and then the idle surge came into play, or since I just changed the throttle body the problem might have always been there, well in the trottle body not in my car exactly. Could somebody please explain to me how the idle when cold and idle when hot sensor thingy work, if I knew how they worked by adjusting the screws then I could figure out how to set them.
Old 04-05-2005, 01:34 AM
coolguycooz coolguycooz is offline
the idle hot or cold thingy is the charge temperature sensor if thats bad then you have to replace it there is no ajustments on it i dont think
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it")
98 GSX 5 spd. (Currently stock, spending all my mod money on body work.)
Old 04-05-2005, 01:40 AM
ned032002's Avatar
Where is this sensor located at and what does it look like?
Old 04-05-2005, 01:44 AM
my bad dude its called the engine coolant sensor i got it know its like a thing that melts once the coolant reaches a certain temperature and it lowers idle but im not sure where its located it should be somewhere on the back of the TB somewhere near the EGR valve or in that general area not sure sorry.
Old 04-05-2005, 01:46 AM
its somewhere on there man it runs to the wireing harness i think but that might not even be your problem. it might not even be on the back ignore that might be on the left side next to the oxygen sensor connector or something.
Old 04-05-2005, 01:51 AM
ned032002's Avatar
the engine coolant sensor i got it know its like a thing that melts once the coolant reaches a certain temperature and it lowers idle but im not sure where its located it should be somewhere on the back of the TB somewhere near the EGR valve or in that general area not sure sorry.its somewhere on there man it runs to the wireing harness i think but that might not even be your problem. it might not even be on the back ignore that might be on the left side next to the oxygen sensor connector or something.
Ok which wiring harness are you talking about and is the sensor easy to find and easy to replace and how important is it to have fixed? Will this cause me to burn lean or rich because if it does then I'm not throwing a CEL.
Old 04-05-2005, 02:03 AM
Dont think it would change the mixture all it does is when the temperature in the coolant reaches a certain mark it melts like a little thing and that causes it to lower idle most likely that isnt your problem since once the thing melts it shuts off the higher idle mode or whatever not too sure man wish i could help you. but im pretty sure it wont change your mixture. thats mostly your 02 sensor
Old 04-06-2005, 11:45 PM
ned032002's Avatar
If oil from the valve cover gets into the spark plug holes, will that cause this problem? When the problem first came up I changed the plugs and wires after already doing that before (the first time I changed the plugs I didn't gap them), I found that after I changed them the car seemed to run much better and the problem seemed to have gone away. What do all of you think?
Old 06-19-2005, 07:58 AM
ned032002's Avatar
What do I have to do if I want to change my ECU? Not to another kind but just to see if it fixes my car. I do still have this problem and many others. What do I have to do to get to the ECU I was told that it is inside the center counsel under the radio and etc.?
Old 06-19-2005, 10:17 AM
lorddarkice's Avatar
lorddarkice lorddarkice is offline
its behind the radio. but i dont think that is your problem.
1990 Honda Civic Hatch - 3 motors, SOLD
1998 Honda civic EX - nothing done, SOLD
1990 BMW 325IS SOLD
1992 Plymoth Laser RS SOLD
1992 Mazda Pro-to-gay Given away
1995 Saturn SL2 SOLD
2002 Toyota Camry LE V6 bone stock.
