Go Back   Automotive Forums Car Chat > Saab > 9-5
Old 04-04-2005, 10:00 AM
brolin1 brolin1 is offline
Question hiccuping/stalling while driving
I have a 99 9-5 4 cyl. manual transmission 70,000 miles. As of last Friday, the engine hiccups/seizes momnetarily while driving (happens at a variety of speeds and randomly). The hiccup is more jarring in 1st and 2nd gears and less so in 5th gear. Happens for a split second and when it happens it seems like the occurences are clustered together. Fro example, on a 1/2 hour trip this morning it happened twice and about 15 minutes into the trip.
Any thoughts and suggestions on what is causing this are appreciated.
Old 04-08-2005, 11:00 AM
Re: hiccuping/stalling while driving
UPDATE:
It turned out to be a crankshaft sensor. If you're having the same "symptoms" I'd have your mechanic check that first. If that's fine, then check then the throttle body and finally the DIC.
