Old 04-04-2005, 07:47 AM
mickbench's Avatar
mickbench mickbench is offline
Preparing Resin Parts
I want to make sure I’ve got this right, before I make a total mess of this. I’ve just got an SAS Nissan R34 Nismo Resin trans kit. It’s a little rough around the edges, but I think this is how they come (I’ve never worked with resin before). Now I will list my process to get the parts installed and painted, and if my steps are wrong someone please tell me.
First I sand the parts to get the edges nice and test fit to ensure they fit.
I then wash the parts in oven cleaner to get the silicon mold residue off – ensures the primer will stick.
Sand the parts all over with 600 grit paper
I then prime the parts to see where I need to fill and sand more
Fill and sand the bad parts
Re-prime
Test fit
If all OK, and smooth surface and test fit fine I then attach to the body and use CA glue. Normal plastic cement will not work, so it has to be CA super glue. Will Tamiya CA be OK?
Once fitted I then prime the entire body the same colour primer and job done, ready for top colour coats.
Am I right, or have I missed a step?
Old 04-04-2005, 07:54 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I only wash mine in washing up liquid and then lightly sand with 2000/1500 grit then prime.
Yes Tamiya CA is fine for fixing to the body, but be careful not to get too much on the plastci body/resin as it'll be a bauuger to sand off.
also try nmot to get any in the panel lines (if you follow me).
The rough edges are normal, SAS stuff has less flash and rough edges than most Resin parts manufactures.
Steve a.k.a. Hiroboy
Old 04-04-2005, 07:59 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Preparing Resin Parts
No need for owen cleaner if you ask me, like Steve I only wash it in water and liquid soap, I use 800 grit paper for realy rough parts and 1200 for the rest (600 will leave deep schratches).
So take one cup (glass) fill it with water and liquid soap and leave the parts in it for a day, then scrub it with tooth brush all over, then sanding then washing again, primer, repair, primer, wet sand with 2500, colour ......
Sasa Jelic
SCALEMAKERS
Old 04-04-2005, 09:41 AM
Mad Mick Mad Mick is offline
Yes, soapy water for cleaning the parts. Just done a R34 with a SAS Nismo bodykit, fitted lovely to the body. Will post pics once its finished in the next week.
Mick
Old 04-04-2005, 09:54 AM
mickbench's Avatar
Re: Re: Preparing Resin Parts
Mick
Welcome to AF -
How did you clean the hood vents up? Mine has a small amount of excess resin in all the vent corners. Looks like it might be hard to get sand paper between the vent holes, and dare I risk a hobby knife to cut the excess off?
Also, sounds like soapy water is enough.. I did seach and read on here about oven cleaner, sounds over the top now.
thanks all..
Oh - SAS kit does look good. Should make my R34 look great once I get it fitted..
Old 04-04-2005, 12:10 PM
Jay! Jay! is offline
Horizontally Opposed
And always, ALWAYS wear a breath mask while filing resin. The dust is killer. Really.
Be safe!
Hierarchy of Subaru:
(Click to see mine!)
Old 04-04-2005, 01:13 PM
mickbench's Avatar
Hmm - I don't think these resin kits are for beginners.. I've just had a go at sanding the flash etc and it's not easy..!! Erm, I think I might actaully not bother using it just yet and wait until my skill level is good enough. I just can't see how you can get the part to fit nice and sand it without taking too much off..
I've just ruined the side skirt.. I think resin parts are too advanced for me. I will admit, I thought the parts where just replacements for the in the box parts..Doesn't appear to be that way.. lots of work required to make them fit, and my putty work is not good, in fact I've NEVER done putty work before..
Shame, as it looks nice - just too advanced for me at the moment.. Plus I've took the hood of already meaning the skyline is now - for the moment a write off kit for me. I'll put it to one side and stick with out of the box builds for the time being..!!
Old 04-04-2005, 01:56 PM
Hiroboy's Avatar
No No No don't give up yet, can we see a pic of the side skirts. I find a quick filler for holes etc is Tamiya CA and use some Zip Kicker which is a CA Accelerator making it set instantly.
If you want send me down the parts and i'll clean them up and sort them out for you.
Old 04-04-2005, 02:44 PM
mickbench's Avatar
Hiroboy - Here is a picture of the parts. I will say now, it's perhaps not the parts at fault here - but me. I just don't know what I'm meant to do in regards to cleaning them up. I honestly thought it was the same as box parts. Get them, glue them on and lightly sand and prime etc..
Not as easy as I thought.. Eyes opened now, time to see what can be done.
OK - I've spent two + hours on them already, and sorry to say I've broke a hood vent - it was so fragile and I was trying to remove the excess resin. One of the side skirts has been ruined as I sanded too hard and removed too much material. And the front bumper has a crack in it, right at the bottom. It was actually like that when I got it, but I think it's a mold issue and needs to be filled, plus the top bumper has hole in it, needs filling. No ones fault just mine as I'm only on my third model and not really in the know when it comes to resin parts.. Can't fault me for tyring though.
I've sent you a PM.
Old 04-04-2005, 03:04 PM
NOMADGAMER NOMADGAMER is offline
dont give up.
but if you do, i'll but the kit and t-kit from you.
Old 04-04-2005, 03:17 PM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
i heard sanding resin inside without a mask and shit is bad for you so when you do sand do it outside just in case wouldnt want any sick modelers
Project Lexus Revive
Old 04-04-2005, 04:04 PM
mickbench's Avatar
Originally Posted by NOMADGAMER
dont give up.
Hmm.. You won't want to buy this kit now mate.. I just attempted to put the hood that came with the body back on again and made a right mess of it..
Seemed to work at first, but the glue as melted the sides and it just fell off.. The kit is ruined.. It's my fault for being too clever.. I thought you just brought the trans kit and fitted the parts.. I had no idea you had to sand resin parts, and even that the dust was harmful..
Little mad at the moment, as I spent around £35 on that kit (paint, trans-kit etc..), and the body is only good for the bin for sure..
Another lesson learnt, this time I've not got away with it. Ruined a kit, so I'll take a break for the rest of this week and start a new kit next week.
What I will do, is buy a new R43 kit, of ebay if I can cheap and use the body, so as not to waste the work on all the rest I've done so far. But not this week.. I'll leave it now. My temper has gotten up and I'm about ready to throw the model at the wall..
Thanks for all the help, and the kit would have been great - It was me. I'm not "ready" for resin work at the moment.. I'll try again in a few months when I've built some more kits, and I'll use the ruined R34 body for putty work practice..
Old 04-04-2005, 04:36 PM
Amazon's Avatar
Amazon Amazon is offline
I think we all sometimesfeel like you Mickbench.
You`re inspired and carry away, and all of asudden, parts don`t fit, e.t.c. " -I`ve ruined another kit. $$ down the drain. Why didn`t i continue birdwatching as mommy wanted,for a hobby.." . Do like i do:
Put the kit away. Down the box. Bury it in the pile. Then after a while when some time have gone, some nice models have left your bench and reside in the cabinet, you discover that kit again. That kit that caused you frustration. The kit that was "ruined". You take the parts and look. Mock up some. Get the ideas flowing. "-It doesn`t look THAT bad.If i cut this and add strip plastic here and.." you think. And suddenly it wasn`t as bad as you once thought
Many of my best kustoms have started as "sawed-to-pieces-ruined-kit"-projects. Remember, we can´t learn if we don´t make mistakes
Newsflash: Diecast sales fund terror activities.
Old 04-04-2005, 05:58 PM
if you seriously made a mess of it and are fed up, and can send me an email with pictures, i'd gladly purchase it from you.
i seriously dont want you to give up on a project, because anything is salvageable.
i cant my own resin parts, so i know how hard it can be for a beginner.
reason i'd be interested in purchasing it is because i do 97% american cars. i ve never worked with tamiya, i only have one fujimi model in my stack of 190 models.
again, working with resin can be difficult, but nothing is ever scrapped.
think about it, and shoot me a pm. i'll gladly give you my email via pm
NOMADGAMER
Old 04-04-2005, 06:28 PM
RallyRaider's Avatar
Zomby Woof
Man I'm sorry that didn't work out for you Mick. If it makes you feel better I'm sure most of us have bitten of more that they can chew on occasion. Now get back on that horse and build something as cool as that Modena in your sig.
