1964 missing 318
I have a 1964 Savoy with a 318. Cylinders #1, 4, 6, and 7 don't fire. (Every other cylinder in firing order) I have actually pulled the wires on all of these cylinders at the same time without changing the way it runs. The plugs are wet so I think I am getting fuel. I have changed plugs and wires, set the points and timing and rebuilt the carb. Help!
Re: 1964 missing 318
Very odd. One side doesn't work. There are 2 things to look at. Both of them are in the distributer. Check the base, where the points make contact, check to see if any of the points have flatened out. This would cause a no spark condition like you describe. I would guess 4 of them are rounded. The other possiblity is the distributer cap. Perhapes 4 of the posts are corroded, or gone.
Thanks,
I will check the base tonight. I beleive it is OK though because I can pull the plug wire from any of the missing cyliders off the distributor while the engine is running and watch the spark jump from the distributor to the wire. (it looks like it is firing) The cap is fine - I had already checked it. thanks for the help Darren |
Okay then, 2 other possiblities. The plug wires are bad, or the spark plugs themselves are bad.
You can swap plug wires and see if it changes which ones don't fire. Or pull a plug from the good side and bad side and see if they both fire from a plugwire from the bad side as well. |
