Old 04-03-2005, 11:22 PM
skinsr4reel skinsr4reel is offline
01 Grand am SE HELP!! Concerning A/C and Heat
Ok everything has been fine, but I noticed today when I turn on the A/C or heat it doesnt work on low settings, but when I put it on Medium or High it works fine...nothings wrong. Why wont it work on low settings anymore? It was working fine this morning, but i went out quick later today and it wasnt working. Could it be a fuse? Its weird that only medium/max settings would blow air.
Old 04-05-2005, 12:07 AM
Hoags's Avatar
Hoags Hoags is offline
Re: 01 Grand am SE HELP!! Concerning A/C and Heat
I had a 98 Pontiac Montana with the same type of problem, it turned out to be the electrical connection at the blower motor. Some how or another the plug was working loose and only the #4 fan speed (out of 5 speeds) would work #'s 1-3 & 5 would not work. I un-plugged the harness and plugged it back in and low and behold I had all 5 speeds working. I don't know if that is your prob. but it is a no cost process of elimination. With any luck it may take care of your problem
Good luck
Old 04-05-2005, 01:18 AM
trixtaz trixtaz is offline
Your blower motor resister is probably gone.
Its a pretty easy fix... and the part will probably run you about $35-40 at an aftermarket shop.
Your blower motor resistor is probably gone.
