Go Back   Automotive Forums Car Chat > Chevrolet > Corsica
Old 04-03-2005, 10:13 PM
chuck's chuck's is offline
no headlights
I've got to work on a 89 Corsica in which the headlights do not come on.I believe that it does not have DRL.I have checked the fuses on the side of the dash and it appears that the headlight switch is allowing power to come out for the head lamps.I think the power the will go to the dimmer switch which will control the high/low beam.Is the dimmer incorperated within the turn signal switch,or is it a stand alone switch?Is there a DRL module which recieves a signal and then puts the lights on?Are there relays that may not be functioning?Any help would be appreciated.thanks.
chuck's
Old 04-04-2005, 10:39 PM
88CORS 88CORS is offline
Re: no headlights
chuck's
I'm pretty sure that it is a stand alone switch but not 100%, also most headlights I have dealt with all didn't have relays, That DRL module also was not put on most domestic systems until 95'(I think). The rest is up to you
"I'm Mister Mister, when I get pissed you get mist"
Old 04-05-2005, 07:48 PM
Re: no headlights
Thanks for your input.I read a few other threads and found some other info.
chuck's
Just did the job.Took about half an hour.Thanks for all the help.
