Old 04-03-2005, 08:10 PM
samsons samsons is offline
99 cavalier stopper running and no longer starts
While driving down the thruway my heater stopped working. Then the check gages light came on in my car. I took the next exit off the thruway and pulled into a gas station. While pulling in my car suddenly died. There was some steam coming from the hood and there was no antifreeze in the resevoir. My car will turn over, but it will not start. The only idea I have is a blown head gasket. Could it be something else?
Old 04-04-2005, 05:57 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: 99 cavalier stopper running and no longer starts
Was the car over heating at the time this happen?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 04-04-2005, 06:14 AM
Yes, it was over heating.
Old 04-04-2005, 06:42 AM
Ryan066 Ryan066 is offline
did you burn or leak the coolant?
could have been clogged and it had excessive pressure to pop the rad cap off and u lost it all and it wont start now that theres no coolant in it.
how many KM on it?
Old 04-04-2005, 09:51 AM
It has been leaking coolent for some time. I have been having to top it off every 4 months or so. When it died I put some water in the radiator, but it still wouldn't start.
There are 90,000 miles on the car.
Old 04-04-2005, 03:12 PM
Sounds like a HG failure...
when u check the oil is it milky colored?
Old 04-04-2005, 11:30 PM
ok I checked the oil and spark plugs tonight. Everything looks fine, there is no milky color or water in the oil or spark plugs. At this point I am pretty clueless. Could it be a relay or computer malfunction? The engine turns over and it's getting gas. It just won't fire up. Checked the spark plugs and they are firing. What about the thermostat? Could that be malfunctioning and not allowing my car to start? I don't understand why my heater was blowing out cold air just before it quit running. The car got hot but it never made it to the "red danger zone."
Old 04-05-2005, 02:28 PM
still has coolant in the car??
id flush the system and put new coolant in. and check commpression.
Old 04-07-2005, 02:29 PM
does anyone think that it could be the timing chain. That's what one of my friends thinks. How can I tell and how could the timing chain break givin the circumstances?
Old 04-07-2005, 05:00 PM
check too see if the belt/chain snaped off but if it did I think it was die right away rather then over heat...
it might have skipped a tooth but then it would just run crappy I would think
