Old 04-03-2005, 05:50 PM
nalgman's Avatar
nalgman nalgman is offline
dead in stop
hello guys.
i have this problem.
i ran my blazer 1990 2wd 4.3 z and runs great
the engine is a rebuilt, and these are new components cap,rotor,sparks,wires,filter of gas and air,timing correct,map ,iac cleaned, so the problem is when i run my blazer runs with no problem, but when i got 25minutes of use and make a long stop like 3minutes stop the car starts to shake a little like it's tryin to die. sometimes it only dies . i tun it on with no problems .
so i never in life ever cleaned the egr. so im thinkin this is the cause.
what do you think??
nalgman
Old 04-03-2005, 09:48 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: dead in stop
usually if its egr it will lack proformence with it
Old 04-04-2005, 01:24 AM
nalgman's Avatar
I guess ???
hello.. ok it's not the egr..
1 hour a go i was drivin my truck and was very very Faster and perfect to me.. all was normal.. but when i get to my house y just pressed the stop pedal for 5 minutes and the problem starts.. and when i move the wheels to the right slowly the power steering was making some noise.. and the voltmeter and the oil pressure go down... but in a second going alive...
so after that each 5 seconds the engine was tryin to die.
i heard that the revolution speed of the engine was lower..
HELP please
thanks Nalgman
Old 04-04-2005, 01:27 AM
Re: dead in stop
ok, hows the alternater doing? how olds the battery? and when was the last time afull tuneup was done? and as to idel speed being lower, either the fan kicked on, or you have something like ac or defrost running and the ac pump started worken
Old 04-05-2005, 12:59 AM
nalgman's Avatar
Re: Re: dead in stop
the alternater it's ok, the battery New, last tune up 1 month..
no AC or defrost. maybe it's the idle speed.. i dont know..
this can cause the idle speed been to low??
:S hard to find..
Thanks anyway
Nalgman
Old 04-30-2005, 07:32 PM
nalgman's Avatar
hello guys...
i still have this problem of the dead in stop.
same thing... runs perfect until it warms up.. after that , runs rough and stalls.
so, i cleaned the EGR today and the TBI plus injectors and other stuff.. and nothing..
my truck blinks the 24 code 3 times. and i know that my coolant sensor it's not working.. what is the 24 code?? and the coolant what can affect???
thank you guys!!
Nalgman.
