Old 04-03-2005, 05:03 PM
mattfox6 mattfox6 is offline
Brake question
I have 2000 Mustang and I just got a brake job done on the front and rear with rotors turned also. They were telling at the brake place that I need new calipers. How long are calipers supposed to last? Thanks in advance.
Old 04-03-2005, 07:13 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: Brake question
The calipers are very reliable. I say go to a different shop to have your brakes worked on. They probally FUBARED them, or tried to force the rear calipers in. Our PBR calipers are extremely reliable, and Ford is not the only car maker that uses the exact same calipers.
The rear calipers are racheting calipers designed for ABS systems. You need a tool that twists the pistons in the calipers as it pushes them in.
If you do deside to change the brake calipers, then you might as well upgrade to Cobra R spec front calipers, which will cost you less than $400 for all the parts needed to upgrade, which are Calipers, pads, rotors, and brakelines.
I do my own brakes, it's cheaper in the long run, and I don't have some shop attempting to empty my wallet.
My ride at my site Silverstangs.
Old 04-04-2005, 09:21 AM
Thanks for the reply. I thought they were very reliable, but I wanted to make sure. Not only that there was no leaking and/or any cracks on any of the calipers. Nor did I lose any of the pads. I hate it when mechanics try to swindle you.
Old 04-04-2005, 09:42 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Brake question
They are full of shit!
A 2000 needing new calipers, tell them to ef off.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-04-2005, 01:39 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
I'd like to say that calipers are usually a very reliable part. But that does not mean they do not go bad. I did my friends 00 GT brakes and when i went to do them I noticed that one of the front PBR calipers was leaking oil out the piston seal.
So while it is very unlikely your caliper is bad it could be so. But unless you notice your brake fluid reservoir is going down or your brakes fells funny. You don't have a caliper problem.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
