Old 04-03-2005, 04:37 PM
Scott82 Scott82 is offline
Clutch will not disengauge????Help Quick Please
Ok got all the kinks in the motor worked out and i want to drive this sucker and my dad is leaving tomorrow morning and things are always easier w/ 2 people. I can't get my clutch to disengauge, i have the d15 vtec using the 89 HF Tranny, i used the 93 civic si clutch kit w/ the z6 flywheel, since the clutch kit came w/ a throw out bearing for a hydo tranny i used my HF one, What have i done wrong here, did i use the wrong clutch kit or what, i was told that i could use this kit as long as i used the z6 flywheel. Is the 89SI throw out bearing differ from the HF? What could be causing the prob, We also have the clutch cable adjusted as far as it will go and it still will not disengauge. Help Please. I want to get this thing going while i have an extra set of hands around. Thanks Scott.
Old 04-03-2005, 05:38 PM
Re: Clutch will not disengauge????Help Quick Please
i am going out to take the tranny off real quick and i'll be back in to see if anyone has any suggestions so if i don't answer replys right away it's cause i am taking the tranny out. Thanks Scott
Old 04-03-2005, 05:47 PM
Hybrid1990crx's Avatar
um i never heard of anyone using a hydro clutch on a cable trans. what does the clutch pedal feel like?
Old 04-03-2005, 05:52 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
im using a hydro clutch with my cable trans and it works fine, i also used my 91dx throwout bearing and its working all good. it might have to do with the clutch cable. take the clutch cable off the bracket holding it in, and pull up on it and the clutch arm should come up alittle and when it stops, thats where you clutch is engaging so then tighten the clutch cable via that little screw weird black circular thing.
Team Lonely Drivers
Old 04-03-2005, 07:54 PM
nothing worked, i am putting the old kit in
Old 04-03-2005, 09:10 PM
ok here's a new one. I put a little lock tight on the flywheel bolts and stuff, well turns out it ran down onto the clutch pad and pretty much supper glued my clutch disk to the flywheel. So civickiller, you think if i get it all cleaned up and not use locktight on the bolts everything will work ok w/ my HF throw out bearing.
Old 04-03-2005, 09:31 PM
guarenteed
Team Lonely Drivers
Old 04-03-2005, 09:36 PM
Cool tomorrow i'll put it all back together and see what i got. Things are a little tight w/ that new d15vtec in there than w/ the HF cause of the location of the collant hoses and all the new wiring but we got it out ok but i felt like a dumb ass when i saw that lock tight on the clutch disk and flywheel, we actually had to pry the clutch disk from the flywheel to get it off, but we didn't crack or damage anything so it's all still good but man what a pain in the ass
Old 04-03-2005, 09:44 PM
make sure you clean it really good
Team Lonely Drivers
Old 04-03-2005, 10:18 PM
What would you clean it with, i was going to get some 180 grit sand paper and sand it a little to get the locktight off and clean it w/ laquer thinner so there isn't any residue left.
Old 04-03-2005, 10:25 PM
yeah sand paper should work for the clutch but just dont sand too much down. and a razor for the flywheel should clean that off
Team Lonely Drivers
Old 04-04-2005, 12:05 AM
Thanks for the help man, hopefully it'll be on the road tomorrow. I'll let you all know, i am sure you expect me to since i have been asking so many damn questions here lately, but definatley thaks to everyone that has helped cause it would still be in the begining stage if AF wasn't here and you guys didn't help out the way you do. Apreciate everything. Thanks Scott
Old 04-04-2005, 12:21 AM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
nice job. and brave of you to tackle the job on your own. wish i had the right equipment...
Old 04-04-2005, 12:29 AM
Re: Re: Clutch will not disengauge????Help Quick Please
The only thing that i needed air tools for was the crank bolt, everything else is hand tools. I did it that way so i didn't break anything. Also a sauldering iron isn't very expensive so that's all you need besides 8mm(dizzy) or philips head, 10mm, 12mm, 14mm, 17mm(used the most it seems like), 19mm(tranny fill), adjustable wrench for o2 sensor, and a big hammer. and from there it's just doin it, oh wire strippers are handy for a swap too. There are other tools to get and use that can make the job easier but escentially that's really the majority of what you need to get it done minus all the parts to use the tools on. but honestly as far as the stuff to do it, if you have some old steel rims you don't even need jack stands, but they are nice to have but it's just takes really wanting to get it accomplished.
Old 04-04-2005, 12:33 AM
Sorry forgot the torx bit and some ratchet extentions for thos hard to reach places. like the tooth brush commercial.
