Old 04-03-2005, 03:27 PM
chevyal chevyal is offline
My 95 silverado feels like its cutting out
Ok. I go to start my 1995 1/2 ton Chevy Silverado ext cab. runs good. as i start to back up, it makes a really loud rumbling sound that you can feel while sitting in the truck and you can also hear the rumbling sound while being outside the truck. It does this only in rev. It feels like to me that its trying to cut-out. Any help would be much appreciated.
Old 04-03-2005, 11:52 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: My 95 silverado feels like its cutting out
If an engine is getting un-metered air, it will do that. Usually a small hole after the metering device. The engine torques in a different direction in reverse, so in your case the hole is being sealed in forward, and opened slightly in reverse.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 04-05-2005, 03:25 PM
where is the small hole after the metering device located near ??
