Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 04-03-2005, 02:12 PM
tophermo tophermo is offline
Intermittent electrical problems
I have a 97 Intrepid, 3.3 liter. Recently when the car is started the power window, locks, a/c do not work. The air bag light also comes on. I think it might be the ignition switch, but I'm not sure. Any help would be appreciated. Thanks in advance.
Old 04-03-2005, 05:46 PM
1thunder 1thunder is offline
Re: Intermittent electrical problems
yes very common problem for these issues
Old 04-17-2005, 11:41 AM
Thanks!
Hey 1thunder thanks for the reply. I haven't been able to dig into the problem yet but I did take a look, and it looks like the top and bottom shroud for the steering column need to come off along with the tilt lever. Other than disconnecting the battery, any other tips you could offer would be appreciated. Thanks in advance.
Old 04-17-2005, 07:40 PM
AWP9521 AWP9521 is offline
Yes, the ignition switch is held on with 2 screws, these screws are an Inverted Torx type screw and you need a special socket to remove them.
Old 04-18-2005, 06:12 PM
yes you are right just remove these covers and the tilt lever and i believe you may have to move the multifunction switch to access these torx screws and i have been able to remove these torx screws with a regular 6 point socket just tap the one closest in size or you will have to purchase a very small torx socket and if you purchase a switch from dealer the screws come with switch then you can match up socket size ahead of time but all said this is not a big job 20-30 minutes if all tools are handy
Old 04-19-2005, 10:36 PM
Thanks!
Yeah, I bought the switch and I actually have the correct socket for the screws. I forget what the real name is but we used to call them gorilla screws. I have no idea why but...
Hey thanks again for all the info.
