Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-03-2005, 02:02 PM
187eclipse 187eclipse is offline
Throttle body help
What is the LARGEST throttle body i can get for my 1997 2.0 GS. Where can i find it and how much is it. Thanks
Old 04-03-2005, 07:36 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
i'd say is 60 mm, and you should be able to find it at www.modernperformance.com, and for the price, they have it for 220 bucks, but you might be able to find it cheaper,
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 04-03-2005, 09:22 PM
Whathits14 Whathits14 is offline
Re: Throttle body help
60 is decent, im sure you could find larger...I don't know much about NT parts but Dsmtuners.com has an extensive catalog, you might want to look there. You should have a lot of mods on your NT before you would need a throttle bod
Old 04-04-2005, 07:54 AM
kjewer1 kjewer1 is offline
AF - Advisor
People with turbo cars run 9s on stock 60mm throttle bodies, I cant see looking for a larger one. There have to be more effective uses for your dollar...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
