Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 04-03-2005, 01:03 PM
rick11 rick11 is offline
Angry Killed my speedo
While removing the car radio, i noticed a tiny spark from a red wire behind the radio. The wiring for the radio seems to be a real hash by previous owner!
I started and drove the car but the speedo is not working nor is the mileometer. Although the radio has power (cd goes in and out but it does not seem to work)
Fuse 12 (7.5a - radio, check control and instruments) had blown. So I changed this but still the speedo or radio do not work.
I noticed the red wire has a crimp connector on the end but can't work out were it is connected to if anything? Is it to the instrument panel somehow or is it just coincidence that this fault has developed at the same time?
Thanks very much for your help...
Old 05-10-2005, 09:24 PM
shhsrockstar shhsrockstar is offline
I had the same problem
Make sure you have a good ground on your radio (chassie ground)...then replace the fuse..and everything should be good to go!
Old 05-12-2005, 02:41 AM
ionizer ionizer is offline
yeah deffo sounds like u have a short somewhere....if all fuses are intact it should be ok. try to check if some of the cables behind the radio is busted or so and try to find a really good ground for the radio and hopefully your problems should be solved.
