Hey guys, I got a friend with a 93 Formula and he just had his mechanic put in a set of 4.10 gears, everything seems to be working great but they whine like you wouldn't believe. The mechanic said they are slimed correctly and that they just need to be run for a few hundred miles to break in. So do the gears need to be broken in to stop the whining or did he do something wrong when he put them in because I read on another thread that some whining could be caused from using a impact gun instead of a torque wrench and a breaker bar. Any help would be appreciated.
thanks -josh |
Re: rear end gear question
sounds your friend got a problem... |
If you used GM Gears, then they're not setup correctly. Whether he didn't shim them correctly or used to much force to install them. I'd have him double check them and use a TORQUE wrench to put everything back together.
DarkblueTA GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit 2007 Nissan Titan Daily Driver. 2* advance
Well what brand gears are they?, cause certain manufactors that use alot of nickel cause whining. Also it is true that new gears do cause whining due to excess heat generated during the break in period but it should not be extremely excessive. Tell your friend good luck.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
They are Richmond gears, so if you might be right DarkBlueTA.
thanks for the quick replys! -josh |
