Old 04-03-2005, 10:57 AM
BKLYN87 BKLYN87 is offline
Code P0401 96 Graaand Am Gt 3.1l
Check engine light came on. Had code read says P0401. Anyone know what the code is for. Thanks.
Old 04-03-2005, 11:44 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Code P0401 96 Graaand Am Gt 3.1l
This code has to do with the EGR valve. Insufficient flow. All that means is that either the valve has gone bad or the passageway leading to the egr has become blocked . You can clean the passageway by removing the valve and phlenum and then using a wire brush to clean out the passageway. You may need to spray it with carb cleaner to loosen the carbon. Once this is done make sure to clean up the gasket surfaces and reinstall the phlenum.
Old 04-03-2005, 11:45 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Its a EGR sensor code. Its most likely a problem with your EGR solenoid. Here is where you can look up codes http://www.troublecodes.net/OBD2/Pcodes.shtml .Good Luck
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
