Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 04-03-2005, 07:08 AM
D17beta D17beta is offline
APEXi V-AFCII or any APEXi unit on D17s
i recently bought a APEXi V-AFCII from a friend, its brand new, but when calling a online tuner store for looking for pulleys and talking to the guy about the new find he told me,. APEX can't get the D17s down right using AFCs and i'll have nothing but problems and that i should just sell the unit, take the money and pick another mod. what do you guys think, and please tell me you know someone or are running one of these units. and if thats the case, i could use some pointers on some basic settings your running. my car '01 civic EX sedan 5spd. intake/header/pulley/exhaust. thanks
Old 04-03-2005, 11:42 AM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: APEXi V-AFCII or any APEXi unit on D17s
Opinions vary on that topic- I for one do not support using the V-AFCII (the only one that works correctly) on our cars. ITs like beating a dead horse. The car is set to engage at the correct RPM no need to change it. Which pully did you get? That also has no effect on a D17 engine its just eye candy. If you plan on racing the car I would suggest boosting it first then worry about a vtec controller/e-manage system, being that there is no ECU upgrades for our engines. I believe Hondata cut the project and is not producing products for the 7th gen. If your interestig in doing some readin on the topic/ installing it yourself here is a DIY wireing diagram.
clicky
03.IS300.MT.LSD. 'Supra in Training'
Old 04-04-2005, 10:58 AM
Re: Re: APEXi V-AFCII or any APEXi unit on D17s
clicky
sad to hear the APEXi V-AFCII unit isn't so great for these cars, i still would like to see a D17 hit an APEXi doctor's dyno. anyone else have some experience with this combo. dyno?
about the pulley; unorthodox ultra street lightened underdrive crank pulley. their claim: 2hp is gained for each pound taken from the setup, this accounts for 85% of the gain, then they're underdriven slightly (not enough hurt accessories) that nets the other 15% since the oem pulley is around ten pounds in theory we net 16.5hp at the flywheel. performancecenter claims 6-10hp regained for D17, regardless mod is felt bigtime on the road, throttle is very quick, runs smooth as glass all the way up, vtec engagement is now felt with a smack, not just heard. as for other sets ie. AEM, ya i feel they're just eye candy. but i really like unorthodox, well made, less than 200 bucks, highly recommend.
Old 04-04-2005, 12:28 PM
BrodyP's Avatar
AF -Advisor
^^ Unorthodox excellent productI also had them on my car and had them install it for me at there shop..I only used it when I was running my amp and system. Didnt really feel a need otherwise. But overall a good product no complains price is worth it for there product.
Edit: that was on my old car not the civ..
Old 04-04-2005, 12:52 PM
sivic02's Avatar
sivic02 sivic02 is offline
What most peope use the vafc for is air/fuel adjustment, without new cams changing the vtec engagment is pointless. But almost every car out there can squeze a few extra hp out of a/f adjustment.
Here's to being single, seeing double, and sleeping triple
Old 04-04-2005, 01:13 PM
BrodyP's Avatar
AF -Advisor
^^ Would you recommend using E-manage instead?
Old 04-04-2005, 01:33 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
do the new D have the harmonic balancer built into the crank pulley like the old ones? Cause if they do, switching out the crank pulley for one without the harmonic balancer will cause damage to your engine.
Empty Pockets Racing Member #1
Old 04-04-2005, 01:50 PM
sivic02's Avatar
Was this for me? If so, yeah I would probably suggest e-manage over just an air fuel controller. You can get more exact air/fuel adjustments and with the ignition harness you can also control ignition timing. I would reccomend a tunable version of hondata over any of these though, just my opinion.
Old 04-04-2005, 02:05 PM
BrodyP's Avatar
AF -Advisor
Re: Re: Re: APEXi V-AFCII or any APEXi unit on D17s
Yea that was for you dude..You said what I thought you would.. I would recommend E-manage as well. But unfortunitly on our D17 unlike your K20 Hondata does not produce a product, not any ECU upgrade out there for our weak engines.
Old 04-04-2005, 02:10 PM
sivic02's Avatar
Well ill be a monkeys uncle... I thought for sure they would have some sort of ecu upgrade for yalls d17's. They are pretty popular engines, more so than the k20a3 in my si. Oh well, e-manage all the way!
Old 04-04-2005, 04:51 PM
please explain, you have me concerned about this balancer. i know UR claims to far exceed OEM specs, machined to 0.001 tolerance. do you have a pic, or a link to what the harmonic balancer looks like, or just a rough description.
Old 04-04-2005, 05:10 PM
BrodyP's Avatar
AF -Advisor
Some reading
Harmonic Damper
Old 04-04-2005, 08:52 PM
sivic02's Avatar
Dude i had a pretty good understanding of what a harmonic damper does, but that article is kick ass. If I had to use one word to sum it up it would have to be "pimptastic"
Old 04-05-2005, 10:58 AM
BrodyP's Avatar
AF -Advisor
haha good word
Old 04-07-2005, 02:27 AM
Re: Re: Re: Re: APEXi V-AFCII or any APEXi unit on D17s
Some reading
Harmonic Damper
this isn't good at all. i'm going to take it back off. we already talked about other pulleys being eye candy, but what do you think about AEM overdrive tru-power alt. & PS pulley set. the reason i ask is, i'm thinking i could maybe trade the unorthodox for them. thanks again..
