Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-02-2005, 11:49 PM
jackjordan86 jackjordan86 is offline
What is the biggest rim i can fit on my 02 S-10 with out it rubbing?
I have a 2002 s-10 lowered 3" up front and 4" out back, whats the biggest rim i can fit without it causing problems. And also could you tell me the difference between a FWD rim and a RWD rim...and could i put a FWD rim on my truck...thanks
Old 04-03-2005, 08:58 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: What is the biggest rim i can fit on my 02 S-10 with out it rubbing?
the difference between a "FWD" rim and a "RWD" rim is typically the offset. It depends on the rim size and the actual offset of the FWD wheel in question to determine if it would fit on your truck. I've seen S10's with 22's but they had to cut stuf to make them fit. Usually the biggest you can fit without cutting is 20's
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 04-15-2005, 07:16 AM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: Re: What is the biggest rim i can fit on my 02 S-10 with out it rubbing?
w/ a 3/4 drop 20s are going to probably going to scrape on a big bump. Go to a shop that sells custom rims they will be able to tell you for sure, thats probably your best bet. w/o seeing the truck i couldnt tell you.
