Old 04-02-2005, 11:29 PM
crusenblazer crusenblazer is offline
Send a message via AIM to crusenblazer Send a message via Yahoo to crusenblazer
Exclamation 95 blazer ignition control module
I'm trying to find the icm on my 95 4.3l vortec blazer. I don't really know where to find it I took off the distributor cap an didn't see it. but i didn't know if I had to take out the whole distributor or if the icm is located somewhere else. Thanks
Old 04-03-2005, 05:57 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
If you have the side post mounted distributor, then you don't have an ignition control moudle per-se. You use a crank sensor and reluctor. The crank sensor comes off the timing cover at about 7 o'clock position, and the reluctor is on the crank inside the timing cover.
