Old 04-02-2005, 10:03 PM
TurboDuck's Avatar
TurboDuck TurboDuck is offline
3.3 and 3.8 Same Trans.???
Can anyone tell me for sure if a 3.3 trans. in a Grand Caravan is the same as the 3.8 trans.? Mine is out in my GC with a 3.8. (It was wrecked and broke the housing..) The Hollander / Junk yard guys say they are not the same, and want many more $$ for the 3.8 trans. (They are not nearly as plentiful around here.) Everything I'm reading and by looking at them, they look the same to me, but I'd hate to go through changing it to find out it won't work.
Has anybody done this??
Thanks in advance, Gary.
Old 04-02-2005, 10:57 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 3.3 and 3.8 Same Trans.???
the 3.3 and 3.8 are the same block, so a tranny out of either one is interchangable.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 04-07-2005, 08:19 PM
EZFrank EZFrank is offline
I heard the same thing i heard that it depends if its a 3 speed or 4 speed. unfortunatly mine is a 3.8 4 speed and they want a ton of money for it can not find to many of them.
[IMG]http://[/IMG]
Old 04-07-2005, 08:27 PM
vamc's Avatar
vamc vamc is offline
A delaership can tell you if they are the same. that info is not a sectet.
Old 04-08-2005, 12:08 PM
TurboDuck's Avatar
We actually have quite a few in junkyards in my neck of the woods (Central Ohio) A lot of them are the 3.3 / 4 Spd. combo. So the prices are fairly reasonable.
I've seen a lot of negative posts regarding these transmissions, but they've always held up ok for me. The key is to change the fluid regularly and always, always, always, use the right fluid. (ATF +3) And, make sure that if you have a prob., the diagnosis is correct. I once bought a real nice LeBaron Convt. (cheap) that was diagnosed as needing a trans., it turned out to be a bad relay. (Cost me about 5 bucks to fix......) :-)
Thanks, Gary.
