Old 04-02-2005, 09:48 PM
murph7727 murph7727 is offline
Question No reverse, goes forward a little??????????
I have a 96 grand caravan. one day while driving up an incline the tranny gave out. Had it towed to my house. started it and drove it just fine. went to put it in reverse and it acted as if it were in neutral. Later I drove it forward again, this time i got about 3 miles and it went out again. I shut the van off, turned it on and drove home. The van still does not have reverse and the tranny goes out after approx. 3 miles. You can shut it off and back on and will drive for about another 3 miles. Someone please help me out here. It sounds to wierd to be the tranny itself, but all garages I have talke dto say that is what it is without looking at it first! Thank you!
Old 04-02-2005, 10:44 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 3.0 tranny no reverse wierd problem
Solenoid controlled tranny- sounds like electrical or control module issue to me. Sorry, don't know jack about Mopars, but I agree it's not mechanical.
I'd be checking grounds and wiring harnesses.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 04-03-2005, 05:09 PM
I heard from a couple of people now telling me it could be that (solenoid) or speed sensors. Are these something I can test? Where is the solenoid and do I need special tools to get it out? How much are they usually? Could it be something else like broken bands or something? So many questions I have about these caravans, so little time! Thank you!
Old 04-03-2005, 11:23 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
first, check your fluid level. How many miles do you have? The solenoid pack could be a problem; there's no way for you to check it, if it's bad replace it. Primarily, check your fluid level and the condition of it; if it's black or has metal chips, you could a much serious problem. Also, I must ask, if you have had a tranny service recently, did you or the person who serviced it use Mopar ATF+3? If not, that WILL cause problems. You can't your band(s) b/c this transmission doesn't have any bands or overrunning clutches, it's all clutch packs that control all the gearset functions.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 04-04-2005, 02:57 PM
Does anyone else have anything to add? I bought a tranny today for $500.00. I would like to save it if something little is wrong like solenoid or something. Has anyone else had this problem?
