Old 04-02-2005, 08:57 PM
Scott82 Scott82 is offline
It's alive!!!!
Man what a different sound than the old HF, i got a little bit of a high idle but i can get that straightned out i think, but turned out the timing was 180 degrees out, swaped it around and bam, fired right up w/ a smooth idle, like i said it was a little high but it didn't bounce or anything. Thank sgod for the sound of that motor cause i was starting to get worried!!
Old 04-02-2005, 09:07 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: It's alive!!!!
congrats, so what motor did you put in there ?
Team Lonely Drivers
Old 04-02-2005, 09:09 PM
Re: It's alive!!!!
d15 vtec, just curious man, where would you start on the idle. Will the crank angle sensor if it is not set cause it to idle high, and plus i have the hf accel. cable on there, but i have the z6 one on the way.
Old 04-02-2005, 11:17 PM
Re: It's alive!!!!
first make sure hte throttle cable isnt too tight cause it to pull hte throttle open just alitle causing a higher idle. if its loose then turn the idle screw down and it should drop your idle. i just did this today on my dpfi because it was idling high
Team Lonely Drivers
Old 04-03-2005, 01:05 PM
See See is offline
Congrtas on getting it all done.I just got the rest of my parts in yesteday so I will be swapping mine out next weekend.
Old 04-03-2005, 01:28 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
so i was right
good to see u got it sorted out man
Old 04-03-2005, 01:34 PM
CBURKE's Avatar
CBURKE CBURKE is offline
Re: Re: It's alive!!!!
YEAH WHAT HE SAID.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
