Old 04-02-2005, 08:32 PM
smokedu454 smokedu454 is offline
Send a message via AIM to smokedu454
tranny leak!!!
ok guys im back with a bigger problem.. i took my gst for an oil change, and the mechs told me i a tranny leak.. wut does this mean, how bad is it... and wut should i do?
Old 04-02-2005, 08:35 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: tranny leak!!!
Take it to a transmission shop. After I had my transmission rebuilt, it kept on leaking from the axle seal so have that checked out. How bad is it leaking? Make sure to keep an eye on your transmission fluid so it doesnt run to low.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 04-02-2005, 08:49 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
tranny leak
from where is the leak coming from?if you can pinpoint the exact location youll know what it is and where its from.could be tranny,transfer case if awd,leak from somewhere else that might make you think thats what it is or my opinion the main seal.hard to tell on a dsm with as many oil leaks it can have,hehehehe
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 04-03-2005, 12:11 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: tranny leak!!!
There are only so many options. But enough that its impossible for us to offer anything usefull based on the information provided. Potential leaks are:
Passenger side axle seal
Drivers side axle seal
Output shaft seal (AWDs)
Input shaft seal (requires total transmission dissasembly)
One of the 3 case joints
Drain/fill plugs.
I'm also assuming you have a 5 speed. Assuming, because you dont provide this information. Also, "wut" is not a word. "What" is only one more keystroke
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
