Old 04-02-2005, 08:23 PM
2shus 2shus is offline
Ticking noise from intake or engine??
I got my timing belt changed and thanks to all who helped, now for a new problem. I have driven the escort a lot since the belt change and 3-4 days ago after work I started it and their was this ticking like noise that sounded like it was echoing thru the intake manifold. It was similar to a lifter noise but I pulled the valve cover and it is does not seem like a lifter. I put my ear down to the aluminum intake and it seemed to be echoing from inside it. I drove home and when I got their it had stopped. It has done it several times since then but only off and on. Mine is a 91 with a 1.9 liter. I recognized the noise right away because my sister car has the same problem. Hers is a 94 with a 1.9 also and hers started making the very same noise about 2 years ago. She took hers in and they said they would have to pull the head so she let it go and just drive it like it is. She has driven it for 2 years solid with the same noise and has had no driveability problems and it has not gotten any worse. Has anyone else had this problem?? Otherwise what else could it be?
Old 04-03-2005, 07:20 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Ticking noise from intake or engine??
I'd try an upper cylender cleaner like lucas gas treatment, marval mystery oil. Then something simple like an oil change.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 04-03-2005, 08:48 AM
vette_7t9 vette_7t9 is offline
happens to mine, but strange that the noise stops after it fully warms up in approx. 1/2 or so. When i drive with the window and i come to a red light, i can hear it clearly. Still can't figure it out..
Old 04-03-2005, 01:38 PM
Re: Re: Ticking noise from intake or engine??
I have ran lucas thru it once and also ran 2 cans of seafoam thru it, One I ran thru the pcv valve while the engine was slightly revved and one in the gas tank. I also poured Rislone upper cylinder lubricant in the oil. All of this was done before the noise started. I have not noticed it now for a day or 2, maybe it just needed time to work?? Thanks for the reply and suggestions!
Old 04-03-2005, 01:43 PM
chevyn0va1's Avatar
Re: Re: Re: Ticking noise from intake or engine??
I read one time (forget if it was here or on label) saying may take 2 treatments. I could be wrong.
Old 04-05-2005, 09:35 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
If I get my cam off one notch on the timing belt, I get a click. Double checking doesn't hurt.
Old 05-17-2005, 05:41 PM
james223 james223 is offline
Unhappy smoke at start up
When I first start my 1989 Escort in the morning I get a puff of smoke from the tailpipe which will last several blocks
I have been told by Auto Value that it is the valve seals./ What is actually involved to do this.
I have replaced the water pump and the timing belt, plus the front outer axle assembly.
Secondly I need a windshield for this car. I have searched the auto wreckers, but find one from a 1990 which seem to be very plentiful will not fit , it is a little smaller. Could Ford have retooled for this one year?(1989)
Thanks
James
Old 05-18-2005, 11:06 PM
Davescort97 Davescort97 is offline
Escort guy
The Rislone made short work of that hydraulic lifter sticking, but it does thin out your oil and maybe you should change it now that the lifter is unstuck. Castrol high-mileage is good.
