Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-02-2005, 07:08 PM
ribsey ribsey is offline
Unhappy Driveline Vibration
Any suggestions would be great.
I have a bad vibration in the drivetrain of my 94 stang (5 spd). I can feel it at idle and is horrible once I get up to 110 kilometer\hour. Since it does it at idle, it must be something close to the motor and tranny. Has anyone else had this problem?
Old 04-02-2005, 10:46 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: Driveline Vibration
If your getting this at idle, meaning at a dead stop with the tranny out of gear, then it's not the transmission or the driveshaft or your rear end.
It's gonna be the engine, or your flywheel, or pressure plate.
I am going to bet that your probally have a dead cyclinder, or one that is not firing. You did not meantion of this is a V6 mustang, but considering the age, and the fact that you did not say GT or Cobra, I am going to assume that it is a V6 mustang. I wouldn't rule out a blown head gasket that has killed a spark plug, or even a spun bearring.
My ride at my site Silverstangs.
Old 04-03-2005, 06:56 PM
Sorry. It is a 5.0 V8. The motor runs fine but I do have some clutch chatter which makes me think that your suggestion of the pressure plate could be the issue. A new centerforce clutch is in the works. I will do the pilot bearing etc...
Old 04-03-2005, 07:52 PM
Re: Re: Driveline Vibration
Centerforce makes a good clutch, althou I am not using Centerforce in my cars because I am running SPEC Clutches in my cars. I mostly run the Spec Stage 2 or Spec Stage 3 clutches. It is always a good idea to swap the pilot bearing when doing the clutch. I also usually replace the clutch cable, but that's over kill for most people.
