Bleeding brakes
I am having problems bleeding the brakes on a 1995 countour with no ABS
A snap-on bleeder has been tried but no help. The front of the car has been jacked up, no help. The master cylinder has been replaced twice, no help Any suggjestions? Thanks sdlrs |
do it the old fashioned way. open the bleeder valve, have someone push on the brakes, close the valve, depress the brakes. repeat for about 30 times.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
Re: Bleeding brakes
Thanks for the help, we will try it tomorrow and hopefully it'll work. Thanks again
Bleeding brakes
Just to let you know, it was the calipers that were the problem.
The pins had worn and the calipers were moving when you tried to bleed the brakes. Replaced calipers, took care of problem. Rick Last edited by sdlrs; 04-10-2005 at 08:58 AM. |
