Old 04-02-2005, 04:13 PM
mako22 mako22 is offline
Newbie - Simple setup, missing some bass???
Hey tried a few searches but couldn't find my scenario...Thank you in advance anyone willing to school me here, you will probably save me $700 when I blow my setup doing "trial and error"...
Basically I have a stock weak-ass "monsoon" system in my Camaro which I just hooked up a Kenwood KAC 7252 1000W Amp to and am running it to one RFosgate 10" sub in the back (HX2 DVC). Very simple.
The problem is I get great super-low bass out of this setup but not some of the slightly higher bass notes I used to get out of my previous RF sub/LA amp. I tested some songs that I felt had good basslines and it kind of misses them all except that "Miami bass" kind of deep headache-inducing boom. Clearly I need to upgrade the rest of my system, but what can I do in the meantime to get some of the other bass notes -
- turn the filter from low-pass to off?
- where should the frequency be set (40-100)?
any other suggestions???
THANKS!!!
www.mako22.homestead.com
Old 04-02-2005, 10:29 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Newbie - Simple setup, missing some bass???
your low pass is probably set to low. Set it anywhere from 60-100hz to what your desire.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 04-02-2005, 11:40 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Is that your car in your sig....if it is....THAT IS AWSOME!!!!
my .02$$
-Ryan
Old 04-03-2005, 12:50 AM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
I've been a little confused about what a low pass filter actually does... I thought for a while that it cut all the frequencies off below the value it was set at, but logically that doesn't make much sense. If it does cut all the frequencies off above what it's set at, how can you tell when it's above the range the sub is capable of? Also, what's the best method for setting the gains correctly? I've tried listening for it as I gradually turn it up when musics playing, but I can barely hear it until it's almost all the way up (like 90% or more). The other speakers kinda drown it out, it seems.
Old 04-03-2005, 01:08 AM
LPF= the frequency where the cutoff begins. All frequencies ABOVE the LPF are gradually decresed by a certain number (12 db's/octave .... 24 db's/octave....ect.).
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 04-03-2005, 05:49 PM
thepyrofish thepyrofish is offline
Try setting your LPF to 80Hz to start, then tune up or down from there to your preference. To set your gains by ear, you basically max out the deck(if you have a speaker amp, in which case you would follow the gain setting steps for each amp.) or turn the deck as high as you can without distortion on the speakers(if running deck power) then slowly turn the gain on your sub-amp up until it distorts audibly. As soon as it does, back it off a bit. There is a better way to do it with a multimeter, but i never learned it.
Old 04-03-2005, 08:31 PM
Actually you don't want to have your head unit on max volume EVER. The outputs in the HU will clip and ESPECIALLY if you have the bass/treble all the way up it will clip a decent bit before max volume. And distortion is VERY hard to hear in your subwoofer until you are way past optimal gains It's best to use a multimeter or get a song that has a lot of different volumes in the bass. If they're all the sae loudness your clipping if they are louder/ more quiet how they should be then your fine. The song I use is late night tip.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 04-03-2005, 09:30 PM
thanks for the advice guys, I will try that.
Just when I think I've got a good handle on performance, suspension and detailing, now I'm a total newbie again -with car audio!!!
and yes that is my car - thanks!
Old 04-03-2005, 11:04 PM
AndonD454's Avatar
AndonD454 AndonD454 is offline
Send a message via AIM to AndonD454
wow man x2 on the nice car post
1996 Explorer 4.0 V6 4x4
Sold all my shit.
waiting for more money
Old 04-04-2005, 12:40 AM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
You are a gay SOB.
J/K!!! I'd kill to have a car just like that man, it looks awesome even in that blue color. Only thing I'd even think about changing is those wheels, but even they look absolutely awesome.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
Old 04-04-2005, 01:02 AM
Re: Re: Newbie - Simple setup, missing some bass???
[quote=v10_viper]You are a gay SOB.
Old 04-04-2005, 09:02 AM
bjboertje's Avatar
bjboertje bjboertje is offline
yes a bottle of pop IS bigger than my engine, thank you.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 04-04-2005, 10:06 AM
Put some chrome on!!! .... come fix up my stang and I'll install a sweet ass system in your car.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
