Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-02-2005, 12:45 PM
almxdupintegra almxdupintegra is offline
Exclamation Difference between an LS and GSR Header?
What are they?
FRIENDS DON'T LET FRIENDS DRIVE STOCK
Old 04-02-2005, 12:51 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Difference between an LS and GSR Header?
One is for a GS-R and the other is for an LS/RS/GS.
Old 04-02-2005, 01:08 PM
Okay that was a tough one then. My question should be more detailed I guess.
Would a GSR header fit on an LS head and vice versa? What about an LSVTEC conversion? Would the GSR header fit and bolt right up to the exhaust?
Old 04-02-2005, 01:24 PM
CivicSpoon's Avatar
There is no Spoon
No the GS-R header won't bolt-up to the LS, it's a different bolt pattern. For the LS/VTEC, you'd use a header for the head you have. I'm not sure about bolting up to the exhaust.
Old 04-02-2005, 02:12 PM
So now that I have a VTEC head the GSR header should be able to bolt up?
Old 04-03-2005, 09:57 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
All the B series motors have the same bolt pattern on the exhaust side of the head. But the difference between the GSR and LS header is that the GSR header will not have a O2 bung in the B pipe part of the header, also it will be sightly shorter.
Old 04-03-2005, 11:43 PM
CivicSpoon's Avatar
There is no Spoon
Well I'll be damned, glad someone corrected that.
