Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 04-02-2005, 01:36 PM   #1
SVT-bird
'01 BOSE 6-disc error2 code on display
My Pathfinder got this code (error2) the other day on the display whenever I try to play a cd, the first time I tried it it made a funky sound and wouldn't do anything now it takes the disc but that's the eextent of it.
SVT-bird is offline   Reply With Quote
Old 05-29-2005, 11:20 PM   #2
posh06
Send a message via AIM to posh06
Re: '01 BOSE 6-disc error2 code on display
I have an 01 and the same thing is happening to mine, if you find anything out will you please email me? [email protected]
posh06 is offline   Reply With Quote
Old 06-02-2005, 08:25 PM   #3
pathylover
Hey guys,
Your 6 disk is shot. There is a gear that commonly breaks that moves the laser. I took mine apart thinking I could replace it... now I have a Pioneer that plays mp3 cds and has the capability of utilizing the steering wheel controls. Time to move on.
pathylover is offline   Reply With Quote
Old 06-08-2005, 08:45 PM   #4
worldcup
Re: Re: '01 BOSE 6-disc error2 code on display
my 01 has the error 2 code and no longer works. I talked with Nissan, BOSE and Clarion (they make the deck, wherein the problem lies) Nissan and Clarion offered to fix it of course for a fee. I am not choosing this option since the previous owner warned me that there were problems with the 6 cd disc (deck was replaced twice under warranty). I would like to replace the deck and keep the BOSE speakers. I have received different advice, some say need to bypass bose amp others say just need a adapter cable. Can someone please advice best solution.
worldcup is offline   Reply With Quote
Old 06-09-2005, 05:46 PM   #5
jshamilian
Re: Re: Re: '01 BOSE 6-disc error2 code on display
I just changed my radio ( not bose but works the same way ).
They use a non-standard voltage to got between the main unit
and the Amp ( in the rear driver side wall). If you buy a standard
unit with a built in amp you need to lower the volatge.
or I just bypassed the rear amp by cutting and shorting the in->out.
If you need the adapter you can find the name by putting your
car type and looking at www.crutchfield.com, they also sell the normal
wiring adapter.
I also got more info by searching www.the12volt.com
jshamilian is offline   Reply With Quote
Old 10-03-2006, 11:41 AM   #6
nospam4cj
Exclamation Re: '01 BOSE 6-disc error2 code on display
This is a common problem with Factory Bose/Clarion 6-disc changers.
The gears to load and switch CDs are made of plastic that will eventually get
brittle and crack or strip out.
You may want to take a look at how Nissan and Clarion will handle this
problem:
Nissan Pathfinder 01 - 6 Disc CD Changer - HELP
I have also sent emails to corporate and working with the Better
Business Bureau and the State Attorney General's Office for a
resolution.
nospam4cj is offline   Reply With Quote
Old 10-03-2006, 10:49 PM   #7
FixUrNissan
FixUrNissan's Avatar
Yeah i feel your pain . Nissan can send them out to get fixed , it's around 275.00 and your without a radio for 4 to 6 weeks. Witch to me is a no brainier , when you can get a aftermarket radio that does all the same things the factory one does and for less of the repair price , with out 4 to 6 weeks of no entertainment.
FixUrNissan is offline   Reply With Quote
