Old 04-02-2005, 12:22 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Box finishing suggestions **PICS!**
Hey everyone...
I've been working on building my own enclosure for the last couple of months, and I'm nearing completion. I'm going to be sanding the outside for the last time today, which is the last step before painting/carpeting. My question is: which do most think is better? Carpeting or painting? I got a cheap rug at walmart that's too small to cover the whole box, but enough to show me basically what it would look like. I also have a pint of black tinted primer that I could paint the whole thing with a few times. The rug in my car is maroon, and I'd like to find something that matched or looks nice with it, and I'm not sure if that's possible with the very limited supply at walmart. I know that the cheaper (thin and bendable at least) the better, but the only ones big enough had really thick backings. Any suggestions?
Thanks!
Old 04-02-2005, 02:37 PM
Diceman83's Avatar
Here's a pretty good shot of my box while the glue was drying.
Because I'm cheap and don't want to buy a wire pass through thing. I'm only using one of the wires, but installed two in case I wanted to do a parallel configuration later with a different sub.
Here's the inside where the wires come through. In addition to all that wood glue, there's now a layer of silicone sealant on all the inside seams.
This was my first attempt at even building a box, and because of a dumb mistake I ended up making it a flush mount box. The sub still sticks up a little, but it looks pretty good.
There's the carpet I have, which is too small. It looks ok, I guess.
This is the paint I have. It's tinted pretty dark, just about black I think. I'll probably put at least 2 layers of this stuff on.
Well, that's just about it. I'll take some pictures of the innards of my car if it's not raining out too bad. I'm in CT, and we're supposedly having a huge rainstorm. I really don't see much of it, just a bunch of fog.
Old 04-02-2005, 03:04 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: Box finishing suggestions
I think it would look better carpeted. You can get black, grey, dark blue, and tan carpet ffrom wal-mart. Go to the Automotive section and it will be sittin right under all of the floor mats. They call it "repalcement carpet" and its like 8 or 9 bucks a roll. You can prolly get away with one roll, but might need two.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 04-02-2005, 03:11 PM
Diceman83's Avatar
ooo... I was in the home decor section... that's where I got that rug. I didn't know they had more carpet in automotive. I was even there checking out the fog lights . Thanks bumpin! I'm also gonna put some handles on it so it's easier to carry. Any ideas how to secure something like this in the trunk? It's sitting on a thin fiber board panel that's covering the spare tire well, so I can't really attach anything to it. I was thinking some straps connected to the hinges of the rear seat going to the sides of the box.
Old 04-04-2005, 09:27 AM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
also home depot and lowes sell many different types of carpet by the foot. you could get astroturf on your box
Old 04-04-2005, 09:55 AM
L-brackets.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 04-04-2005, 07:24 PM
Diceman83's Avatar
Re: Re: Box finishing suggestions
Originally Posted by bumpinstang77
L-brackets.
I've seriously considered those, but what am I going to connect them to? There's only half an inch on either side of the sub between the wheel wells and it's not vertical surface on the front or back. I'm thinking I'm going to bolt some sort of round flat connector to the sides and loop rope around them to the rear seat hinge. I doubt even that will work though, because there's so much paneling and crap everywhere. I may just end up making some braces that wedge between the rear wall of the car and the back of the speaker. I did that before with some junk in my trunk when I was testing it before gluing, and it didn't budge. I went over some of those nasty long speed bumps that chucks your rear way into the air if you're going too fast over them, and heard everything crunch as it hit floor. I'd like to be able to have the sub in different positions in the trunk, like facing up and foreward, back and up, and back and down. In the pics you can see it's shaped kinda funky. Heh, first time doin it all my self, and that's what I get. It was fun making it though
I'll have some more pics of the amp rack and the wiring soon. Would it be ok you think to make a project thread?
edit:: oh yeah, I bought 2 rolls of dark blue replacement carpet... just where you said they'd be, Bumpin! Thanks a ton! As soon as I get my homework done for tonight, I'll be carpetting that box.
One other random thing, does anyone know what the voltage on the turn-on lead coming from the head unit is?
Old 04-04-2005, 08:11 PM
Get a pic and I'll tell you the best way to connect it.... and if your wonder about voltage from the remote the answer is no don't hook other shit up to the remote wire.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 04-04-2005, 11:03 PM
Diceman83's Avatar
darn... I'd like to turn a bunch of LED's on with a transistor, and I was planning to use the remote lead as the activation voltage. I suppose I could just hook it up to the little light already in the trunk, but I was trying to avoid that. I guess I'll figure out something else besides the remote lead to do it. Thanks for the warning.
Old 04-05-2005, 07:31 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Why not use the amp turn on lead with 12v. relay? Then you can ad as much as you want to that circuit.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-05-2005, 09:56 PM
Diceman83's Avatar
Is a relay different than a transistor? I was gonna use a resistor to reduce the voltage on the activation line to 5 volts, so hardly any current will go that way vs. straight into amp. It's a basic transistor, so I didn't think it would be much of a problem to do this. The turn-on signal wire is only designed to have a steady voltage applied to it, to let the amp know when to power up and start amplifying the signals coming from the head unit, right? I suppose I could hook a potentiometer up to the actual speaker wire (so I could limit the voltage going to the the LED circuit at a given volume level) and get a mosfet transistor (one that can turn on and off really quickly) and have it go nuts with the music, which would be pretty cool. I'm not sure I wanna mess with that, though. Ideas ideas ideas... so much fun
Old 04-06-2005, 09:36 AM
Why are you trying to hook it all up off the remote and bullisht. Just hook it into the power coming from the battery. I would suggest not running anything off the remote wire..... its a good way to fry headunits. If any power gets backfed that HU goes pop and frys the fuck out of itsself.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 04-06-2005, 06:34 PM
Diceman83's Avatar
I'm not running it off the remote... I'm using power from the battery, I just don't want it on 24/7. I want to use the activation signal from the head unit to turn on power to LED's (from the battery). LED's only allow voltage to flow in one direction, as do transistors (if connected properly), so there's very little danger to the head unit.
I think it will work just fine, if I can figure out what the voltage on the turn on lead is, and get it reduced to about 5 Volts.
Old 04-06-2005, 07:09 PM
Hey dumb shit, that's what relays are for. I thought you and your buds are some sort of car audio prodigy or something? That's car stereo 101 dude. He needs something like this http://cgi.ebay.com/ebaymotors/ws/eB...&category=6763
Now that one says that it has a diode in the harness which is commonly used for starter kills on alarms. I'm not worried about that, you need only the relay.
They are very simple for his application. It has 5 pins on the back of it. pins 85 and 86 will be the trigger from the stereo and the other to ground. Pin 30 would go to your high amperaged 12v constant (or ignition if you want) and then #87 would go out to what ever you need to give 12v. to turn on. This COMPLETELY takes the load off the "trigger" wire from the stereo. These relays are usually rated at 20 or 30amp so should work great.
FYI> transistors wouldn't do anything for you. Actually, they could create even more of a load than what you are trying to keep from happening.
Pioneer 4900mp
Orion C63 Coax rear
Old 04-06-2005, 08:32 PM
Diceman83's Avatar
I'm lighting up some LEDs... current load is going to be about 250 mA... I don't need something that will give me 20 or 30 amps Sigh... all I wanted to know was what the voltage on the remote turn on wire was... My head unit manual gives me a max amperage (500 mA), but no voltage. I've tried to test the voltage with my multimeter, but the thing doesn't seem to work properly for voltages that low or something. Yes I've use multimeters before, and this particular one sucks.
